Results 1 to 25 of 25
    Senior Member Halifax's Avatar
    CT
    Default Lynx/B needs a seat upgrade
    Hi Gents,
    I'm looking for recommendations for upgrading the seat in my '82 Lynx/B. Currently, the seat consists of a couple of taped metal sheets and two taped pieces of 1" thick "Super Space Age Foam" from SR Racing.
    Last autumn, three days after the Glen race, I tore my L sacroiliac back muscles in a fall in a work-related accident (I'm an ecologist, I stepped in a cryptic woodchuck hole in a high meadow) and I was literally crippled for a month. My MD thinks that my car's lack of good support was a major contributing factor.
    My crew chief won't let me race until I solve this. Anyone have any ideas?
    Thanks!
    FV Lynx/B #8
    NC
    Liked: 304
    Without seeing what you have it's a bit hard for me to comment intelligently, but that hasn't stopped me before...
    In my car (Citation) I added a curved floorpan primarily to drop my butt another inch lower. This required a new seating arrangement.
    At the front, between the bulkhead and my butt I used 2" foam (PET from lowes) glued up to make 4" thickness, then shaped the bottom to conform to my pan. On the backside (toward the driver) I cut and shaped at the angle that matches my butt/thigh area. I then covered the foam in a layer of 5 ounce glass just to hold it all together in an impact. It puts about 5 inches of foam between me and the bulkhead.
    Behind me is another bulkhead that presents an impact to my rear in any rear end impact. I made a similar piece to cover this area which matches the angle going into my fuel cell/cover. My butt sits in a very small space between the two pieces of foam, directly on the pan. I do have a camping foam mat that lays in on all this. If I had the room I would provide a foam piece to the very bottom.
    I read a bunch of stuff here on Apex before I did this. Search seating and Mr. Pare's comments about using the solid foam for some guidance if this route seems appropriate to you.
    Torrington CT
    Liked: 481
    I disagree with your doctor - if you feel comfortable in the car, then it is probably okay. If you are not comfortable in the car then you need to do some work - remembering there are a lot of FV guys who just sit on the floor and the fuel cell.
    However, I also think many manufacturers do not do a good job of supplying a proper seat. A full fiberglass seat would be a start toward a good seat and a base for a bead seat or similar foam seat.
    ChrisZ
    Bradenton, FL
    Liked: 14
    Quote Originally Posted by Halifax View Post
    Hi Gents,
    Thanks!
    EIS bead seat kit. Its the best and safest seat for a formula car hands down. Made to your body shape. For multiple impacts/ crashes without replacing, and no messy beads like a usually bead seat kit. Its the best $350 you can spend.
    Hope this helps,
    Jon Updegrove
    86 Red Devil F440 F-Mod
    97 Van Die men FC
    New Hampshire
    Most FVs do not have room to make a proper beat seat.
    These are pretty good Harry this is what I have in my car
    https://www.pegasusautoracing.com/gr...roupID=BACKPAD
    We had a great weekend at Thompson wish you could have joined us!
    Mark Filip
    Contributing Member flat tappet's Avatar
    Vermont
    Hi Gents,
    Thanks!
    when i sold you the Lynx, you were a young guy with a perfectly good back...now look at you!! JUst kidding my friend. I had some good stuff(foam) from Pegasus racing..blue on the outside..thick but fairly firm
    Vancouver BC
    Liked: 49
    If you have enough room to spare, the bead seats (or the fancy EI$ stuff..) are definitely worth it.. Both for safety and comfort!
    It's quite a bit of work to get one done and fitted, but it might have been the best improvement I ever made to my car. Ideally, the thicker the better, but I think if you have enough room for the 1" foam, you should have room for the beads.. Even a little would be better than none
    CT
    Liked: 22
    Default Lynx Seat
    Harry I had some seating issues with the Lynx B I had. Bead seats are great but as stated, not a lot of room in a Lynx and it will also raise you up a little so you might have a great seat then a big roll bar safety issue.
    I picked up one of these on E-Bay, cut off the lower leg area, plus a little trimming for fit and added a very thin soft foam. Worked great.
    http://www.ebay.com/itm/Lightning-Li...4cb8b8&vxp=mtr
    Austin, Texas
    Default Seat Kit
    This is the ultimate solution unless you want to pay someone $1800 to do it.
    http://motorsports-sw.com/site/custom-seat-kits/
    Dean
    Wolf GB08
    Austin
    www.motorsports-sw.com
    Vancouver BC
    Liked: 49
    You can make the bead seats as thin as you want.. There is a suggested minimum thickness for safety, but 1/4" of beads under your arse is still better than 1/4" of foam. My seat probably has 3" of beads around the sides filling up the corners of the cockpit, but it's fairly thin under my butt - I just adjusted the beads until I was happy with my roll bar clearance and could easily pass the broomstick test.
    Is the Lynx B that much smaller than a Caracal D?
    Anyway, not trying to argue folks, I'm just a firm believer in the benefits of bead seats and would hate you to discount them unless it really is impossible to make them work
    If comfort is higher on the list than the safety aspect of a good seat, you could also try the 2 part expanding foam stuff.. I was going to do that until I found a great deal on a bead kit that someone ended up not using. Having something that conforms to your body shape is awesome. There's no flopping around on corners and you get a lot more feel for what the car is doing. Of course I was 140lbs when I first bought the car and I didn't really have much body fat to conform to a fiberglass or sheet metal seat - I had to make a seat that conformed to me instead.
    NC
    Liked: 304
    ...but 1/4" of beads under your arse is still better than 1/4" of foam.
    Tiago, I assume you're talking about foam rubber or something similar. 1/4" of PET foam sheet is, IMO, better than 1/4" of beads from PET foam, just because of the uniform density. YMMV.
    Barry
    Senior Member Jean-Sebastien Stoezel's Avatar
    Winnipeg, MB
    Liked: 15
    This is a poured in seat I just built for my lynx b. It fits fine with 1" thick of material under my butt and my back. I'm 5'11" and 160lbs.
    Western Canada Motorsport Association (WCMA)
    FV #0
    Vancouver BC
    Liked: 49
    Barry
    I was comparing the typical EPS foam in most bead seat kits to the soft-ish foam most folks use for padding.. I'll take your word that given the same material, a sheet would be better than beads, though! Most helmet liners are made from beads rather than a solid carved piece of material - although I suspect that's just how expanded polystyrene works.
    Senior Member Amon's Avatar
    Medina, Ohio
    Liked: 174
    Any idea where a bead seat can be purchased?
    Mark
    NC
    Liked: 304
    Tiago,
    The solid piece is beads formed together under controlled conditions into a sheet. Helmet liners are formed the same way.
    Barry
    Austin, Texas
    "You can make the bead seats as thin as you want.. There is a suggested minimum thickness for safety, but 1/4" of beads under your arse is still better than 1/4" of foam. My seat probably has 3" of beads around the sides filling up the corners of the cockpit, but it's fairly thin under my butt - I just adjusted the beads until I was happy with my roll bar clearance and could easily pass the broomstick test."
    It is worth reading up on the EIS foam seats and padding NASCAR and Indy cars use. This is the same material you buy for your approved rollbar padding.
    EIS is superior in every way.
    If you poll people that have used both bead seats and EIS you will get a clear answer.
    Dean
    Wolf GB08
    Austin
    CT
    Liked: 22
    I've owned both a Lynx B and a Caracal D, the frame rails are 2X4 beams and you actually sit between them which is about 14 -15" wide. In my Lynx I couldn't even fit between the rails, ( I'm 6' 195 lbs) I had to use the Kart seat to raise me up a little to get off the rails. In my Caracal D I used the thin fiberglass factory seat that came with the car. I once tried to add 1/4" foam to the sides and couldn't get into the seat. While it might not be the safest way to sit in the car, my old bad back loved the hard seats.
    Ohio
    Liked: 247
    Quote Originally Posted by turnbaugh View Post
    Wheres the cheapest place to buy an EIS seat? I'm on a budget
    Burlington, WI
    Liked: 391
    I used one of the forum sponsors, Speed Seat, this winter to make a new seat for my FV. I had them do the pour and covering, but they sell the SFI rated foam kits (not the bead seats) if you want to do your own. It was the best thing I've ever done for my car. The seat is amazing. For what it's worth, in the 3 races since I had them make a seat, I set 3 new track records. I've never been so comfortable in the car.
    Michael Varacins
    Vancouver BC
    Liked: 49
    Quote Originally Posted by veefan View Post
    I hear ya, makes sense. My car started out as an exact replica of a Caracal D, but the previous owner carved out some hip-clearing-scoops in the frame rails I'm 5'11" and was 140lbs at the time (I've put on 15lbs since then.. Still trying to put on a bit more!) so I needed quite a bit of padding to fill the gap.
    I've read some stuff about it, I believe you are right! I bought and made my bead seat before the EIS stuff was readily available to us small time folks. Still, we're talking about FV where an EIS kit (let alone a professionally made seat) starts to become a fair percentage of the value of the car Even bead seats are a hard sell. I do believe they (bead seats and EIS) are worth it, not just for safety but for performance - as Michael Varacins pointed out. It really made an unbelievable difference to be so perfectly set in the car.
    Anybody used the EIS seat for more than a couple of years? How is it holding up?
    My EIS roll bar padding never lasted very long before it became brittle and crumbly.
    If the EIS seat is 25% better than a bead seat when both are new but only 1/3 as good when 3 years old....a cost benefit analysis is in order (aren't they always? ) Aging out isn't an issue for the pros, for the club racer I would think it's a legitimate concern.
    Member Wolf Pack Racing's Avatar
    The Wolfs Lair........Indy
    I have used the Bald Spot Sports Creafoam bead seat since I started racing open wheel. I have had numerous large impacts and it has always protected me. This is the only seat technology approved by Indycar. http://www.baldspotsports.com
    Quote Originally Posted by Amon View Post
    Mark
    Austin, Texas
    I have been using my seat for 1.5 years. No sign of deterioration. Still as comfortable as new. Not brittle or cracking. I suspect the cover protects it from sun and any other contaminants.
    Dean
    Wolf GB08
    Austin
    CT
    Thanks for the exhaustive review, Gentlemen.
    FV Lynx/B #8
