What is the spec for the FM Radiator, what VW radiator do they use?
I don't know the make & model# (I think it's an early 80's VW Rabbit) but the VW part # is 171 121 253 D.
There's a little bit of prep work: you need to thread two of the plastic bosses for the radiator mount (VERY CAREFULLY) with an M6 or 1/4" thread. There's also two stock bleed line that need to be cut off & capped. A #10 screw (again carefully threaded) with silicone does the job.
thanks, that looks like the exact replacement
Just did this my self. Thanks for the good info.
