Results 1 to 20 of 20
    Michigan
    Liked: 237
    Default Cosworth Vega Race Engine
    I am looking for advice/opinions/other info as to the suitability of a Cosworth Vega engine for an old formula car I am building.
    Don't really care if it's not period correct as the car itself is not very valuable. Are there sources for performance parts. Any thoughts appreciated.
    Brown Deer, WI
    Liked: 47
    What about a more modern Ford (Cosworth Engineered) DURATEC 30 V6.
    Aluminum block and heads, 200-240 bhp stock, fuel injected, cheap and easy to find.
    Just a thought,.
    Ian
    Ian Lenhart
    Level 11 Creative
    www.level11creative.com
    lenhart06@yahoo.com
    Liked: 1868
    From what I can tell, there basicly is nothing out the for replacement parts - what you get with the motor is all you are going to get.
    Was an OK motor, as long as you didn't try to pull too much HP from it - the block would flex a lot. The few engines that were raced seriously never finished any races that I'm aware of - lots of cooling and oiling issues.
    Liked: 1474
    Everything I've heard echo's Richard. Somewhere out on the web there's a site that talks about the cossie vega and the various shortcomings.
    If anyone needs one I believe there's one out here in ridgecrest. saw it at one of the local shops in the back yard.
    Michigan
    Liked: 237
    Thanks for the responses. I was afraid that it might not be one of the better engines that Cosworth was involved with.
    I'm looking for an older looking twin cam engine like the Lotus Twincam, without breaking the bank. Thanks for the suggestions and info, any other possibilities ?
    West Union, IL USA
    Liked: 319
    Alfa-Romeo, Lancia, Fiat.
    Alpine California
    Liked: 273
    Default Here's an engine for sale
    Link to a Lotus Twin Cam complete for $5,000 that's not a bad price at all.
    http://www.apexspeed.com/forums/showthread.php?t=63265
    if you could find an Alfa 1600 twin cam cheap enough that might be a good choice. Parts for these can be pricey though.
    Gary Hickman
    Edge Engineering Inc
    FB #76
    Quote Originally Posted by Gordy View Post
    Don't overlook a souped-up Kent. It's the same bottom end as a Twincam at half the price (or less). Check out Burton Power for go-fast parts. They happily ship to the States, and with a 1750cc version on twin sidedraughts you'd be at or above the power of a Twincam. Plus it bolts right in since it's essentially the same engine.
    Liked: 291
    Gordy, what "old formula car" are you building pray tell?
    Liked: 1474
    Bob Hatle has a hotrod kent in his FB titan for exactly the reasons Stan quoted - much cheaper than a Twincam, similar performance.
    Memphis, TN, USA
    Liked: 413
    Vega Cossie engine was used in the day but had to be built with the special GM-supplied racing block. Otherwise, as Richard says, it flexed way too much. IIRC about 185 hp was all you could reliably get out of the stock block. The special unit was used to build AJ Foyt's closed course record engine at over 600 hp. Non-turbo with a racing block should easily get 300.
    Charlie Warner
    fatto gatto racing
    Liked: 1868
    If i remember correctly, the "racing" block was cast iron.
    Liked: 1868
    Slight issues with the alu block at about 290 HP:
    Contributing Member Snakedriver's Avatar
    West Virginia
    That Fiat TC engine out of the 2000 Spider sure looks good.
    Leo
    1965 Cooper T-75
    1966 Morgan 4/4
    2009 Lotus Elise Type 25
    Liked: 291
    i thought that record setter used an Olds Quad Four variant?
    Valley Hi,Ohio
    Default olds not vega
    I thought Foyt used the Olds Quad4 engine for his closed course record:
    http://www.youtube.com/watch?v=6mQvE5lykic
    Later the Quad4 went in the Sports 2000s for the pro series.
    Liked: 1868
    Yes, it was the Quad 4 in Foyts car in '87. the later record runs (1992) were with the Aurora V8.
    600 hp wouldn't get you even close to the speeds AJ hit - the Quad 4's were pumping out a bit over 1000 hp.
    ww.outrightolds.com/index.php/story-of-olds/spotlight-on/olds-aerotech
    Contributing Member Tigaman's Avatar
    Virginia Intl Raceway
    Liked: 67
    The Fiat 1608cc (80x80), 1756cc and 1995cc motors are terrific. As long as the oiling system is sussed, they live at high outputs for a very long time.
    -Peter Krause
    1984 Tiga SC
    www.peterkrause.net
    "The Driver is the Greatest Performance Variable in the Racing Equation"
    Liked: 291
    gives new meaning to the term "engine cutawaY"
    Cedarburg, WI
    Liked: 86
    I think you could JB Weld that back together.
    Matt King
    FV19 Citation XTC-41
    CenDiv-Milwaukee
    KEEP THE KINK!
