**ALL PARTS SOLD**
Fire sale...everything must go. Make an offer. The more you take, the better deal I will give you on it. I will update the list daily.
Add shipping costs to the prices from Barrie, Ontario. Pickup can be in Barrie, Toronto area, or Bradford. Anyone attending the F1200 AGM can also pick up parts there.
all pictures here:
http://s238.photobucket.com/user/int...?sort=3&page=1
13 different lengths x Tie Rods / push rods - $5 with no rod ends, $8 with one rod end, $10 with two rod ends
2 upper, 3 lower x Turkey legs - $10 each for used
4 x built spindles (poor condition) - $5 each
2 x chrome pitman steering arm - $15 each
1 x 4-2-1 collector (mediocre condition) - $10
5 x Contact points set - FREE WITH PURCHASE OVER $20
7 x Bosch distributors - $25 each, with rotor $30 each, with cap $35 each
6 x distributor cap - $3 each
12 x link pins (used) - $3 each
1 x oil pump set - $15
3 x venturi stack (new) - $8 each
1 x clutch operating arm (new) - $3
2 x front ball joint backing plate (refurbished) - $5
11 x drum (front and rear) – pick your drum, $5
1 x input shaft - $5
3 x Vallis intake manifold - $150
1 x Kapelke intake manifold (same as ones used on big HP cars we have for sale, very close to rules, but still legal. Matches HP made by F1200 legal Autowerks) - $250
3 x steering boxes, good condition – used $20
4 x fuel pump – 1 old style $5, 3 new style used $10
5 x coils (used) – 4 Bosch $10 each, unknown brand $5
1 x oil pump block off plate - $3
1 x BRD front engine mount - $15
2 x oil filler neck, various types - $10 each
1 x box of used brake shoes - $20 for the lot
6 x fiberglass mufflers (actually work!) - $5 each
2 x valve cover (bail type) - $3 each
1 x box of pushrod tubes - $10
1 x 12V starter - $15
8 x silver slotted FV wheels with unusable rubber - $25 each
4 x F1200 wheels various styles with unusable rubber - $30 each
1 x Falken non-K tire, 6 weekends on it - $10
Oil coolers:
5 x 5 row VW cooler - $25 each
1 x 7 row VW cooler - $25
3 x Oil manifold block - $25 each
2 x Oil filter (new) - $5
5/7 row + manifold block + filter combo - $50
Shocks (from left to right)
2 x KYB - $10 each
1 x Fox (right side) - $20
6 x Stock - $7 each
3 x front Carreras - $15 each
2 x rear Carreras (no threaded sleeve) - $15 each
8 x unknown brand, all have compression - $3 each
Gauges
2 x mechanical temp gauges - $5 each
2 x mechanical pressure gauges - $5 each
1 x exhaust temp - $15
ADDITIONAL PARTS:
2 x BRD tails - $60 each
1 x right BRD scoop (some damage) - $10
