Results 1 to 40 of 40
    Member Highroller101's Avatar
    Western Ma
    Default Proud new owner of a '02 prosport
    Just bought an '02 radical prosport. I know nothing about these cars except they are fast, fun, and relatively cheap.
    Purchased Alan Wilzig's car if anyone knows it.
    First question is do they make a larger seat? The one in the car is very small...
    Next question, I have very little information on the car, is there a particular rim size for the prosport? All I can say is the rear tires are 40% wider than the fronts. They're huge.
    Car hasn't been raced since 2007, anything major that I need to do to it?
    Has a 1400cc Sam Nelson engine, ohlins coil overs, pro shift paddle shift not installed.
    DJM Dennis McCarthy's Avatar
    New York
    Liked: 120
    If it was Wilzig's car, it probably pretty pristine....
    Danbury, CT.
    Liked: 1906
    [QUOTE]
    Quote Originally Posted by Highroller101 View Post
    Nothing major except taking it to a prep shop that has experience with Radicals and have it gone through.
    Much less of a production than a funeral.
    Liked: 271
    Default Seat
    They make a wide Prosport seat - we had a bunch of Radicals through here and there was different widths. Best shot is Radical West at Spring Mountain race track although they mostly deal with SR3s. I have a few bits left over upstairs if you need small bits.
    Phil
    Santa Rosa, CA
    I'm also a ProSport owner, and yes, they are very "fast, fun, and relatively cheap."
    The seat was the most unpleasant aspect of my car (other than the absence of a place to plant my left foot -- easily remedied). I ditched the "plastic garden chair" and installed two well-braced aluminum panels which created a form for a very comfortable and supportive bead seat.
    I run 8" and 10" rims with 20.0x7.5's in front and 22.0x9's in back.
    Adding a Flatshifter was a worthwhile improvement.
    Fast, fun, and relatively cheap.
    Western Ma
    I don't have any around me...
    Car is very nice, just needs a fuel pump, not sure which to buy but I know it's a low pressure pump. Or at least I assume because of carburetion.
    Western Ma
    Quote Originally Posted by Phil Creighton View Post
    Phil
    Thanks Phil, I gave them a shout.
    What kind of parts do you have hanging around?
    The car has a roll bar aero kit, but it seems to be missing the part where it attaches to the roll bar
    Western Ma
    Quote Originally Posted by yellowesty View Post
    The current seat is carbon fiber, and the legs are forced upward... This is my biggest problem. Do you have pics of your custom seat?
    The rear tires have to be 11-12 inches wide on this car.
    New York
    Liked: 120
    Call Mike Agnifilo at Stonebridge to sort the car out and for prep work.
    He's not that far from you and you won't be sorry.
    Santa Rosa, CA
    Highroller:
    I tried to PM you, but ApexSpeed says "no."
    PM me with your e-mail address and I'll take some pictures of my seat arrangement and send them to you.
    Yellowesty
    Western Ma
    Quote Originally Posted by Dennis McCarthy View Post
    Do you have contact info?
    The only one stonebrige I found was in NY and he said I had the wrong place.
    New York
    Liked: 120
    Mike Agnifilo
    (203)744-1120
    Western Ma
    Mike Agnifilo
    (203)744-1120
    Gave him a call but he's booked for over a month, any other recommendations?
    Western Ma
    So, I found out why the car won't start, identified it as the fuel pump, tested power at the pump with zero volts.
    I ran a jumper wire from the battery to the fuel pump and it immediately started to pump, car started right up.
    Looked for a fuse and I only found 2 fuses total on the car... Am I missing it? Where is the fuse located? Is there a fuse?
    Contributing Member jimh3063's Avatar
    Easton, Massachusetts
    Default Fuse
    Matt:
    When you followed the fuel pump lead back, where did it end?
    Did you get any setup equipment (Alignment bars, etc)?
    As I mentioned those cars are not street cars need more
    care and feeding. I think there are some radical forums that
    you can ask questions to current radical owners. Just take it easy at first
    and learn the car. They are plenty quick enough to turn you into hamburger if you
    don't show it the proper respect.
    Jimmy
    Jimmy Hanrahan
    jimh3063@yahoo.com
    Sanibel, FL
    Some cars have a Master Kill Switch, then a general power (ignition) switch, then a fuel pump switch. Start following the wiring back from the fuel pump and see where it goes.
    Craig Farr
    2006 Stohr WF1 P2
    FARROUT Racing
    Senior Member fitfan's Avatar
    San Diego
    Liked: 107
    the investment of shipping it out to spring mountain, getting it prepped/sorted there and running it with them, could put you a year or more ahead in the car... run a few weekends with them there, then ship it back when your comforatable with it.
    if its been sitting that long, things like fuel cell... shock re-builds. fire bottle fill. etc.. may need attention. those guys, would know what updates and fixes to address as well as setting it up for you to drive (pouring a seat and such).
    BT29-24 Swift DB1 Matra M530
    New York
    Liked: 120
    Wait the month for Mike, many prep shops are busy right now as the season will start in the northeast soon. Wait for Mike, he knows what he's doing, you won't be sorry....
    Western Ma
    Bringing the car to motion dynamics tomorrow for them to go thru it. Don't expect them to find anything out of the ordinary!
    -Matt
    Race cars:
    2002 Radical Prosport
    1958 Austin Healey Bugeye Sprite
    Western Ma
    Quote Originally Posted by jimh3063 View Post
    Matt:
    Jimmy
    I lost the wire when it joined to the voltage regulator in the side panel... Not before one of the body clips broke off...
    The master switch is fused and it's in tact
    -Matt
    Race cars:
    Western Ma
    -Update-
    Fuel pump switch is the culprit, jiggling the switch made it turn on, will replace the switch!
    -Matt
    Race cars:
    Western Ma
    Got the car back today
    New fuel pump switch
    Moved the seat
    Check AFR on the dyno
    Compression results 150 across the board
    Complete nut and bolt
    Brake and clutch flush with ate fluid
    Oil change
    Diff flush
    Issues: stack dash doesn't rev over 6k rpm...
    -Matt
    Race cars:
    atlanta, ga
    Liked: 136
    I drove a Pro Sport to start the '05 season and I LOVED that little tank!
    I did however get caught out by a little simple hidden fuel filter that was located behind a trap door arrangement (I was only brought in to drive, not wrench the car, so I don't have actual 100% knowledge of the location).
    It resulted in a DNF with about a 30 second lead on 2nd place, so you have been warned! ;o)
    I would not even bother with getting another bucket seat, and do the only thing that can potentially save your ass, and that is a proper bead seat.
    To drive a car w/o a bead seat is like getting onto a car w/o a HANS.
    PS - How do you do a trans flush on a motorcycle engine?!!
  24. #24
    Senior Member Maciej's Avatar
    North NJ
    I think he might have meant flushing the oil in the diff.
  25. #25
    Paso Robles, CA
    Liked: 285
    If your stack tach is reading half of it's actual value, it's likely that it's confused by the ECU tacho signal which may be one pulse per revolution (many bike engine ECU do this). Try going into the stack setup and changing the number of cylinders to 2 (i.e., twice the pulses of a 4 cylinder 4-stroke which is 2 pulses per revolution).
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
  26. #26
    Chevy Chase, Maryland
    I'm in my 4th season in a very early Clubsport and have rebuilt, or made everything on the car. 2013 MARRS CSR champion, leading MARRS and NEDIV series P2 points and current P2 track record holder at Summit Point ('cause someone had to be first )
    I've found sources for nearly everything, have learned a huge amount the hard way, and have a car now that's fast, reliable and easy to drive.
    I have the only full set of bodywork molds on our continent BTW. Nose, tail, side pods, difuser, fender louvers, side skirt, splitter, inner fenders.
    I maintain the Clubsport/Prosport w/ a K8 Hayabusa engine and the right restrictor setup is a competitive SCCA P2 car, and one of the easiest to campaign.
    Shoot me a message and I can get you some links to good information, and I can answer any questions you have.
  27. #27
    Western Ma
    Well I drove the car yesterday for the first time and it was awesome!
    For some reason, I can't connect to my dash anymore
    And I have no idea what rpm I'm at, so when I went WOT, it bogs... But I was told the AFRs were perfect...
    Otherwise the car was incredible! Never driven anything like it! It was awesome and I'm looking forward to the next event!
    -Matt
    Race cars:
  28. #28
    Western Ma
    Here is a picture from at the track
    -Matt
    Race cars:
  29. #29
    Western Ma
    So I ran the car at New Hampshire motor speedway on Monday.
    Learning a lot about the car and how to drive it as well as quirks.
    Anyone that has the hayabusa motor, have you ever experienced the car popping out of gear? For some reason the car doesn't like to downshift into second.
    The dash reads normal rpm from 1k-3k rpm then stops at 4k and if it feels like it, jumps to 6k. I will be sending it to stack for it to be fixed.
    I noticed that my car's gas fill tube is under the bonnet... Is this normal? Or is it supposed to protrude to the outside of the body?
    The car handles very well but I'm very surprised how little "go juice" it has, is this normal for these cars or am I missing something?
    Lastly, looking for advice, it's very disconcerting taking my hand off the wheel to shift, I know paddle shift is the answer and I have one ready to install but I was wondering if I needed to know before I make the decision to do it or not. Car is currently carbuerated, but I have the things req'd for fuel injection
    -Matt
    Race cars:
  30. #30
    Marietta,Ga.
    Liked: 61
    "Anyone that has the hayabusa motor, have you ever experienced the car popping out of gear? For some reason the car doesn't like to downshift into second."
    Most likely a bent shifter fork & maybe more.
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
  31. #31
    Western Ma
    Anyone have a source for a reasonably priced fuel cell bladder? Fuel safe wants to charge 1406 for a 7 gallon bladder and a foam insert. Ridiculous.
    -Matt
    Race cars:
  32. #32
    Florida
    Give eagle a call in WI. Great company and responsibly priced. Have used them for 2 cars now, very happy.
    http://www.eaglefuelcells.com
  33. #33
    Calgary, Alberta, Canada
    Liked: 26
    you could also try sending it to Hartwig Aircraft Fuel Cell Repair in Winnipeg Manitoba. if the cell isnt too bad they do a very good job, provide a Certified Repair Cert and I have always found them very reasonable (for our Continental cells) in so far as pricing, quick turn around as well. as an option, just putting it out there.
  34. #34
    Western Ma
    Guys,
    Is there any way to make this a 1 man crew car? I've been to a few track events and every one I have been to I have had to ask for assistance.
    If I can't get it to work as a one man crew, then I'll have to sell.
    Advice please!
    -Matt
    Race cars:
  35. #35
    North NJ
    Guys,
    Advice please!
    It wouldn't be easy but it is possible.
  36. #36
    Senior Member BennyBad's Avatar
    miami,fl.
    as said it can be done.
    just need to practice at home and set eveything up as you would need to do it by yourself.
    ive run my wf1 by myself for a few years before my son started coming, since my son (crew) has a social life and cant be counted on anymore. havent figures out how to get a umbrella caddy yet at the grid.
    just takes planning and practice BEFORE you go to track.
    benny
  37. #37
    Sanibel, FL
    I am also a one man crew. Get a routine down for belting yourself in. Put a checklist together for the pre session things (fuel, torque wheels, tire pressures, check oil and catch tank, etc)
    Get your helmet, gloves and arm restraints lined up where you can reach them. Master switch on. If you have a camera put it where you can reach the controls. Mine is get in the car with the HANS on and do the harnesses but leave them a bit loose. Helmet on then hook up the HANS. Tighten up the lap belts. Then the shoulder harnesses. Put on gloves.
    There will always be someone paddocked around you that is willing to assist just as you will assist anyone who needs it as well.
    Craig Farr
    2006 Stohr WF1 P2
    FARROUT Racing
  38. #38
    Western Ma
    Quote Originally Posted by farrout View Post
    My issue isn't in the grid or getting in the car, I bought the car for when I instruct, hoping that I could do all maintenance at home, go to the track and just hop in and go when it's time for the instructors to go on track, but the most basic thing I need 2 people for: unloading the car and loading. I need 2 people to put the body on and take it off, nose only. Maybe it's my trailer, but the car only has about 1" of ground clearance with the nose on.
    To check the oil I need to take the rear end off and again, it's a 2 man job. But once it's off, I can do it myself.
    I just moved the fuel filler neck so I don't have to take the nose off every time I need gas.
    -Matt
    Race cars:
  39. #39
    Santa Rosa, CA
    As I mentioned earlier, I also run a ProSport -- track days and racing with a small club that runs "vintage" rules (no contact). I am my own one-man crew. Two issues took some attention:
    Loading and unloading the car: My trailer has its wheels UNDER the floor (to allow the trailer to fit in my home storage spot). That means that the trailer deck is 25" off the ground. I use very long ramps (an 8' ramp from the trailer to a wooden support and a 6' ramp from the support to the ground). Even with long ramps, the car would high-center and scrape the splitter (I load the car tail-first onto the trailer) so I built a dolly with some angle iron and 4 swivel caster wheels. Using my QuickJack, this slides behind the front wheels of the ProSport and increases the ground clearance behind the front wheels from 2" to 5". I also lengthened the wire on my winch control so I can walk alongside the ProSport and "steer" it up and down the ramps by pushing the dolly to one side or the other. Works fine.
    Removing/refitting bodywork at the track: The rear bodywork is the biggest problem -- the front will slide forward and off, but the rear is both bulky and heavy. I fabricated a hinged roller and mounted it, under the bodywork, to the center of the rear ProSport framework that supports the rear body/wing structure. Then I fiberglassed a piece of ¼" plywood to the underside of the rear bodywork, between the wing support braces. When I want to remove the rear bodywork on my own, I undo the latches and, lying on the ground behind the car, raise the rear of the bodywork with one hand and flip the hinged roller to the "up" position with the other hand. Letting the bodywork down on the roller is stable and I then lock the roller in place. The roller is high enough that the bodywork now clears the latch pins and can be pushed down in back (pivoting on the roller) which then gets the front of the bodywork up, past the air intake. The rear bodywork then slides back and rests, vertically, behind the car. Installing is the reverse of removing. A pain, but it can be done by one person.
    Neither of these "solutions" are wonderful, but both work. If you come up with a better approach, please let me know.
  40. #40
    I'm got essentially the same solutions with a few differences.
    - I have a small deck-over trailer as well, and made 2-piece 12' ramps+3' lengths of 2x10 to get the splitter up.
    To avoid high-centering on the rear edge of the trailer, back the rear wheels of your tow vehicle up onto 2 cheap ramps. The rear edge of the trailer drops enough so my 12' ramps are exactly in plane w/ the trailer deck. Drive on, leave the car in gear, drive the truck off the ramps then tie down.
    To remove the rear alone - which I do every time the car comes back in - I remove the center of the roll bar fairing, pull 4 hood pins, undo 4 body clips, and, standing behind the car place the rear of the body against my legs and pull back on the leading edge of the wing to lift the front of the body. It lifts off easily, I step back about 6', set it down them tip it back so it's standing up. Takes less than a minute.
