Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
  1. #41
    NC
    Liked: 302
    Wow, looks almost like long grass with a bit of color added.
    Looks like the crank was stripped also. How was that fixed?
  2. #42
    Rochester, NY
    Default Moreover
    Crank was fine but we decided to use the whole flywheel, pressure plate and disk from the donor engine. This worked great. I've wracked my brain as to why this happened and all I can come up with is a lining piece came loose from the disk an held if away from the flywheel causing massive slippage and heat.
    Interested in other theories, but the clutch was perfectly adjusted and worked great before this happened.
    Check out the blue flywheel!
  3. #43
    NC
    Liked: 302
    I noticed the blue flywheel. Slippage does generate heat!
    I once owned a very hot MG Midgett that would occasionally strip the clutch lining right off the disc. It was not from abuse. I could just let the clutch out in a normal fashion and it would just sit there...
    I went through 3 clutch discs before I found the problem. The flywheel had been lightened and the clutch surface machined slightly. The machinist did a poor job on the clutch surface such that it was not perpendicular to the centerline. It worked just fine until it didn't... probably not your problem here but you never know.
  4. #44
    Plainfield, IL
    Liked: 190
    One more photo of Matt Gordon and his Citation FV conversion:
    Bill Bonow
  5. #45
    Plainfield, IL
    Liked: 190
    Default Gingerman Photos
    OK, I thought all those thousands of FST groupies would be clamoring for the event photos, but nope.....it ain't gonna happen.
    So here it is, the first two rounds of the Hoosier FST at Gingerman:
    Bill Bonow
  6. #46
    Plainfield, IL
    Liked: 190
    Default pg 2
    More Photos
Name:	Gingerman 2014 Rounds 1 & 2 012.jpg
ID:	46380   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 013.jpg
ID:	46381   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 014.jpg
Name:	Gingerman 2014 Rounds 1 & 2 015.jpg
ID:	46383   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 016.jpg
ID:	46384   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 017.jpg
Name:	Gingerman 2014 Rounds 1 & 2 018.jpg
ID:	46386   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 019.jpg
ID:	46387   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 020.jpg
    Bill Bonow
  7. #47
    Plainfield, IL
    Liked: 190
    Default Pg 3
    More Photos
Name:	Gingerman 2014 Rounds 1 & 2 021.jpg
ID:	46389   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 022.jpg
ID:	46390   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 023.jpg
Name:	Gingerman 2014 Rounds 1 & 2 024.jpg
ID:	46392   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 025.jpg
ID:	46393   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 030.jpg
Name:	Gingerman 2014 Rounds 1 & 2 032.jpg
ID:	46395   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 038.jpg
ID:	46396   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 039.jpg
Name:	Gingerman 2014 Rounds 1 & 2 040.jpg
    Bill Bonow
  8. #48
    Plainfield, IL
    Liked: 190
    Default Pg 4
    More Photos
Name:	Gingerman 2014 Rounds 1 & 2 041.jpg
ID:	46399   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 042.jpg
ID:	46400   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 043.jpg
Name:	Gingerman 2014 Rounds 1 & 2 044.jpg
ID:	46402   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 045.jpg
ID:	46403   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 046.jpg
Name:	Gingerman 2014 Rounds 1 & 2 047.jpg
ID:	46405   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 048.jpg
ID:	46406   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 049.jpg
Name:	Gingerman 2014 Rounds 1 & 2 050.JPG
    Bill Bonow
  9. #49
    Plainfield, IL
    Liked: 190
    Default Pg 5
    More Photos
Name:	Gingerman 2014 Rounds 1 & 2 051.jpg
ID:	46409   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 052.JPG
ID:	46410   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 053.JPG
Name:	Gingerman 2014 Rounds 1 & 2 054.jpg
ID:	46412   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 055.JPG
ID:	46413   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 056.JPG
Name:	Gingerman 2014 Rounds 1 & 2 057.JPG
ID:	46415   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 058.jpg
ID:	46416   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 060.jpg
    Bill Bonow
  10. #50
    Plainfield, IL
    Liked: 190
    Default Pg 6
    More Photos
Name:	Gingerman 2014 Rounds 1 & 2 061.jpg
ID:	46418   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 062.jpg
ID:	46419   Click image for larger version.
Name:	Gingerman 2014 Rounds 1 & 2 063.jpg
Name:	Gingerman 2014 Rounds 1 & 2 064.jpg
    Bill Bonow
