Results 1 to 39 of 39
Thread: Header Designs?
    Member zmoore54's Avatar
    Wisconsin
    Default Header Designs?
    We have a 2012 Kawasaki ZX-10R engine going into a 1977 LeGrand. The car is going to be used for autocross and probably wont see anything higher than 90mph. So torque is important to us and more specifically lower end torque. We are going to have the header custom made but aren't sure about the details for stuff like primary lengths, 4-1 or 4-2-1, primary sizes, if we should have all three Ys connect to each other or have some pipe separating the two from the third? if there should be a step in there or anything like that? we also currently have supertrapp muffler and were planning on using it for at least this season (2.5" diameter) However, we do have 100db limit at 75 feet at full throttle and this is actually enforced.
    Zach
    Senior Member JJLudemann's Avatar
    Thailand
    Liked: 36
    Default Re: Header Designs
    Quote Originally Posted by zmoore54 View Post
    Zach
    I'm going to be looking into that soon myself. The obvious thing to do is to copy the stock design's primary diameter and length, the diameter and length after the 4:2, and the diameter after the 2:1. From a fluid dynamics perspective, 4:2:1 works better than 4:1 because you get reflections from two junctions instead of one, and the dual reflections can be tuned to arrive at the right times. In my case I'd like to just do dual exhausts, a single Y going to each side of the car, but my buddy who ran bikes in the IoM TT says that will be down on power and hard to tune the air/fuel ratios. Also, if you run exhausts around both sides of the engine, the second Y or crossover tube will be too far downstream. So that leaves us with a 4:2:1 header that goes to one side of the engine and splits into a dual exhaust after that. This makes one side's path longer than the other side, which in certain cases can be relevant.
    -Jim
    Jake Latham has a used header from a Stohr listed in the FB 4 Sale section.
    It is a right side exit and may work for your application.
    I think you'd be hard pressed to find a "torque header", or someone who could promise you they could make one that produces "more torque than brand x"
    Liked: 292
    point it straight up
    Liked: 285
    If you are serious, I have found a fellow that can design a proper header system. He will ask for significant details like cam profiles, a current dyno sheet and details on the exhaust system used to produce that. A design will cost about $500. If that works, PM me for his contact info..
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Wisconsin
    This is how it turned out.
ID:	47475   Click image for larger version.
ID:	47476   Click image for larger version.
    Liked: 292
    Default COOL!
    or should i say hoTTT..........you might want to shield that cylindrical tank
    Wisconsin
    These pictures distort the true dimensions slightly.. we are 3 or 4 inches away from the oil tank, our major concer is how close to the airbox it is. Keep in mind, the car will only see competition use for a minute at a time. Runing for no more than 3 or 4 minutes.
    San Jose, Ca
    What dimensions are the primaries and secondaries, and how did you come up with them? I see a step in the first primary also. I build headers similar to these, though I pair the cylinders one and two together, and three and four together. Why the different layout here?
    And why the cobbled together third collector?
    Member AEA_Team_Lotus's Avatar
    Providence RI
    Looks very similar to the Radical SR3 design, interested how it works for you? Any intentions of putting it on a dyno?
    Somerset, Kentucky
    Liked: 126
    Burns Stainless algorithm derived header primary length at 13.5" with 4:1 for me for the racing ZX-10R.
    San Jose, Ca
    Have you run this setup on the dyno? Thats pretty short. I'd imagine that would be pretty peaky.
    Liked: 285
    David, If the firing order is 1-2-4-3, why would you pair 1&2 and 3&4 in a 4-2-1 design? Wouldn't the first cylinder in a pair have a different flow than the second cylinder due to the interaction with the previous exhaust stroke? If you pair 1&4 and 2&3, then the first collector see the same pulse for each cylinder (ie. 1 engine revolution from it's sibling), making it easier provide the correct air/fueling as it will be the same for each cylinder.
    I think EFI tuning is challenging enough without having to account for different flow in every other cylinder.
    David Ferguson
    805-238-1699
    Make sure that you read the FB rules for the exhaust height.
    GingerMan Raceway, Michigan
    Liked: 14
    Jay, the owner is not going to exceed 90mph, I don't think he needs to read the FB section on exhaust height, all of eight inches from the ground, what a great rule, do we go 8 or 6? lets do 6, no lets do 8 inches, done and done.
    Good seeing you at Grattan
    Liked: 14
    I'm curious to what comments on this exhaust I had custom made for my bike engine, the work order was meant to produce a 4-2-1 "slip style" ,but lost in translation and magically a 4-1 piece is produced. I tried to talk the fabman into chopping some off and please redo into a tri-y, well that's not gonna fly, I get a 4-1 for a discounted price. Maybe the 4-2-1 will be next and keep this as a spare. I'm pretty sure it was his first time doing a bike engine header, but I also gave him a factory exhaust to study and pictures of other tri-y like rilltech's or vance hine's sidewinder stuff.
    The dimensions are not top secret, 1-5/8 off the head flange, stepped twice up to a whopping 1-7/8 before the hand made collector, looks pretty, looks not like a tri-y, yes I'm a little sad that it isn't what I asked for.
ID:	48104   Click image for larger version.
    Contributing Member Brandon Dixon's Avatar
    Tuscaloosa, AL
    Liked: 127
    Quote Originally Posted by JRMarchand View Post
    At first glance, it doesn't look like those primaries are all that close in length....
    Liked: 14
    Brandon, yes for sure, the lengths are way off, could that be dangerous for the engine as much as it makes the design ineffective? Cylinder 1 and 4 vary almost 100%, That can be fixed, it wont hurt to ask. Thank you
    The exhaust height must be between a minimum of 20cm and a maximum of 60 cm. this is equal to a min of 7.9" and a max of 23.6"
    San Jose, Ca
    Seeing as how this guy is going to auto-x the car, I don't think he needs to follow the FB rules.
    If you don't have the primary lengths at least fairly close to each other, your fueling is going to be all wrong from cylinder to cylinder. If the fab guy didn't know what he was doing, as apparently he didn't if he didn't know what a 4-2-1 exhaust was, I'd have told him to eat the cost. JR, what motor is that?
    I can get my primary lengths just about equal, within a 1/4 inch without too much trouble these days. But it took me a while to get that good.
    Senior Member Jasonrmbell's Avatar
    Florida
    10rmotor are you In the Buisness of making headers I need one
    Jason Bell
    STOHR 2013
    F1000
    f1000bwracing@highwaysystemsinc.com
  22. #22
    Houston
    itza Bimmer
  23. #23
    San Jose, Ca
    Quote Originally Posted by Jasonrmbell View Post
    I don't know that I'm quite in the business of building headers, more like general fab stuff, but I do seem to be specializing in them. I've made headers for stohrs, cheetahs, A-Macs, Reynards, and zinks. Mostly suzuki powered of course, but I've made a few for R1s, and a ZX14RR in the Zink. My two oddball headers were for a turbo nitrous injected VW VR6 drag race motor out of 321 stainless, and a complete exhaust for a McLaren F1GT 3 seater with the BMW V12. Wish I had pictures of that!
    I primarily make 4-2-1 stepped headers out of 304 stainless. I've got lots of customers that will vouch for my work
    If you'd like, PM me your email address and we can discuss further.
  24. #24
    Member sportech's Avatar
    Brighton, MI
    Default BMW Headers
    These are out of 304 for Mike Devins. Pretty much copied the design of the bike header, including the transition between the primary and secondary collectors. I'm sure BMW spent some dyno time designing their header.
    Dave
    Piontek Engineering Inc.
Name:	2014-04-08 19.07.16.jpg
ID:	48117   Click image for larger version.
Name:	2014-04-08 19.07.24.jpg
ID:	48118   Click image for larger version.
Name:	2014-04-08 19.06.56.jpg
  25. #25
    San Jose, Ca
    I'm building a header for a GSXR in a cheetah, and my layout is very similar to that. The main difference is my third collector has some distance between the first two collectors. I'll post some pics later.
  26. #26
    Liked: 14
    Dave, I think those will fit my NovaD, call you after I sort out the problem with my fab man.
  27. #27
    BEEMer
  28. #28
    Default Wanna see some pretty work?
    Check it.
  29. #29
    San Jose, Ca
    Here are some pics. Not the one currently under construction, but its pretty close.
ID:	48135   Click image for larger version.
ID:	48136   Click image for larger version.
  30. #30
    Florida
    Check it.
    What car is that Glenn.
    Jason Bell
    STOHR 2013
    F1000
  31. #31
    Mine.
  32. #32
    Baltimore, MD
    Liked: 14
    Default Nice workmanship
    Very slick Coop.. Who did the work ?
  33. #33
    Some fella north of me one hour - works out of a converted chicken house.
    Motorcycle guy, does a lot of high tech, precision military contract stuff.
    No more info available w/o signing a release!
  34. #34
    Houston
    BEEMer
    You say potAto, ...
  35. #35
    Dam Glenn that looks like welding on a nuclear reactor,,,,,,,,,,,,,, niceeeee!
  36. #36
    St Charles, Mo
    Liked: 159
    Default cool stuff
    There are some really cool and/or strange goings on in the hills of Georgia. I once had the broken bell housing on my can-car welded up......after midnight.....by a guy a short distance from Road Atlanta......who looked like a farmer....but when you entered his very old barn, there was lots of very sofisticated welding and machine equipment. He had an inert gas welding chamber to weld the bellhousing in.....then machined it square again. He tried to refuse any payment.....saying he was glad to help......gotta love the south.
    Jerry Hodges
  37. #37
    Default Ah HAAAAAA!
    Quote Originally Posted by Rick Kean View Post
    You say potAto, ...
    Almost Kean-san, but you must remember...
    "Bimmer" is car,
    "Beemer" is bike!
    Now that I think of it, it's a bike engine in a car...
    My brain just melted down!
    Jerry, I don't know for 100% certain if it's a southern thing, but I'd bet on it!
  38. #38
    Houston
    thaza Bummer no?
  39. #39
    Florida
    Sexy
    Jason Bell
    STOHR 2013
    F1000
