    Liked: 1474
    Default need FM track dimensions
    could someone provide the measurements between the bottom inside edges of the front and rear tires?
    I'm trying to see if a specific set of scales will fit an FM. Thought the GCR would have the dimensions, but it does not.
    front track width is 59, rear is 58 inches. that's center to center of the tires, so approx 52" between the fronts and approx 49" between the rears if using 7" front and 9" rear wide tires.
    Liked: 1474
    Thanks!
