Results 1 to 9 of 9
    Ohio
    Liked: 247
    Default Is adhesive necessary?
    I'm in the process of rebuilding my citation and I've been been doing some research on the best way to attach the pan. For other classes it seems that adhesive is necessary to get extra stiffness, but with FV's some have said that there isn't any benefit from using it due to the zero roll.
    My question is do you think its necessary and if so why?
    Senior Member SOseth's Avatar
    Hendersonville, TN
    No question. YES. Rivets can and will wear away and break. Using a quality adhesive is not difficult nor very time consuming. I would not skimp on the quality of rivets either.
    SteveO
    Liked: 1403
    If you use a good structural adhesive, you question should be are rivets necessary. The adhesive does the real work of attaching the belly pan to the frame. The rivets are there to add peal strength the adhesive does not have.
    In short a "rivets only" attachemnt is probably 25% or less of a bonded joint of adhesive and rivets.
    Burlington, WI
    Liked: 391
    I highly suggest gluing the belly pan on as well. I tried rivets only and they all came loose during the first season. I was constantly drilling and installing new rivets.
    The next season I made a new pan that I glued and riveted. After many seasons the rivets are still solid.
    I would also highly suggest a second inner tray in the foot box. I made a duplicate belly pan from the front bulkhead, notched to clear the pedals, back to the cross member under the front roll hoop. It has upturned edges so it's riveted to the inside of the frame rails. This way, if the belly pan ever gets peeled back from the underside, the inner tray is independant and should hopefully keep my feet from falling out. I had a belly pan peel back about 3 inches behind the pedals once when I got airborn and sheered it off on the roll hoop of another car. I wasn't too far from having my feet fall out.
    Chicago
    Liked: 15
    I did my Citation about 4 years ago and it was very easy. There are plenty of posts here on Apex. I did use an adhesive that was a 2 part mix from McMaster Carr, search and you can find the name. Also used steel rivets not aluminum.
    What made it a lot easier was purchasing Clecos from Pegasus and also purchased a pneumatic rivet gun from Harbor Freight.
    4 years later and I have managed to knock the heads off about 1/4 of the rivets but the pan is still secured to the frame. Be sure to prep the frame rail by cleaning and scuffing up to provide adhesion.
    Marietta,Ga.
    Liked: 61
    Aluminum pop rivets are ok for screen doors, however Cherrymax rivets are better for structural use.
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
    Liked: 4358
    Quote Originally Posted by B Farnham View Post
    To answer your question .... for performance of the zero-roll suspension, not necessary. It is desirable though, for all the reasons noted.
    Liked: 292
    from Speed Sport Engineering........
    "I would also highly suggest a second inner tray in the foot box."
    i like this idea
    Ohio
    Liked: 247
    Thanks for all of the replies, I really appreciate all of the advise. I'm going to go ahead and order some Hysol adhesive later today.
    That's a very good idea, I'll have to look into adding something like this.
