Results 1 to 20 of 20
    Australia
    Default Stohr 2008 head rest /collar
    We have recently purchased a 2008 Stohr f1000 and I am looking for ideas as to how to make the neck collar able to be released quickly. At the moment it is locked by two pins that I would hate to have to undo quickly and I am completely stuck in the car unless I can remove the collar.
    Just seeing if anyone have some easy solutions to this.
    Thanks in advance.
    Cheers
    Ben
    Contributing Member Revs2-12k's Avatar
    Wilmington, NC
    Benno,
    My Stohr collar is secured with the same hex head dzus buttons used to secure the body panels. Take a few of your spare buttons and drill/tap threads for a 1/4x20 stud. Then add wing nuts or small phenolic handles and epoxy in place. These will allow you enough leverage to remove the buttons with gloves. I'll post a photo of my solution later.
    Working hard to enhance my Carbon Fiber footprint....
    2011 Stohr F1000
    www.Area81Racing.com
    Senior Member BURKY's Avatar
    Florida
    Liked: 444
    Quote Originally Posted by Revs2-12k View Post
    Benno,
    Do you mean something like this?
    New Jersey
    I don't know what you have, but I have been thinking about using these:
    https://www.pegasusautoracing.com/pr...asp?RecID=4660
    You can add a strap to make it easier to grip.
    Senior Member David Locke's Avatar
    Indiana
    Liked: 175
    Quote Originally Posted by BURKY View Post
    The self-eject wing-head Dzus is what Stohr provided when I purchased my WF-1 cockpit surround.
    near Athens, GA
    Liked: 841
    Why not just use 'push release' hitch pins -- like stock on an FE ??
    Similar to this .. but you can probably find cheaper.
    http://www.ebay.com/itm/like/310712504106?lpid=82
    And probably something with less protrusion too...
    or maybe put it on the BOTTOM or TOP instead of INSIDE.. ?
    Liked: 1880
    Years ago I modified an older Citation to have an easily released surround. The back center had a pin that stuck back into a hole ( for vertical alignment), and the 2 sides had pins near the front edge that protruded sideways throuh a panel, and were secured by an R-clip. Attached to the clip was a cord that the driver (and corner workers) could easily find and pull to remove the pins. The surround sides were then easily poped out and the whole thing removed.
    You could possibly do a version of that,in place of the dzus fasteners.
    Indiana
    Liked: 175
    I get in and out of the car without removing the cockpit surround, and I've never snagged anything on the wing heads. They don't protrude that far.
Name:	Cockpit surround.jpg
    New Jersey
    I like Richard's idea, something that can just be yanked in an emergency, no fiddling and turning. I think they also make hitch pins the pull to release, instead of pushing.
    Wilmington, NC
    Default Fast & Easy removal of Stohr collar.
    A few pics of my solution.
    Oriented so they align with the airstream.
Name:	Bar Knob for Cockpit Surround.jpg
ID:	44323   Click image for larger version.
Name:	Hillman Bar Knob.jpg
ID:	44326   Click image for larger version.
Name:	Cockpit Surround Buttons 2.jpg
    2011 Stohr F1000
    Australia
    Gday guys and thanks for your responses. I really like the idea of the Dzus sliding clip which is similar to the r clip, and having a toggle attached. currently we have the wing-head Dzus and it is really fiddly and I wouldn't want to have to do it in an emergency and it would probably be impossible if you were on fire and your hands contracted. And having been in a car on fire once I know you are in a real rush to get out
    Now I just have to see if I can make it fit, if it works ill post a picture.
    David unfortunately my 6"4' frame doesn't allow me to slip out... my shoulders get in the way.
    atlanta, ga
    Liked: 136
    Default Curious:
    Have you actually tried to get in and out of the car w/ your HANS and helmet on?
    The reason I ask is I see people get into the car and THEN try to get their headsock/helmet/HANS all buttoned up and it just seems bass ackwards(!)
    Are you a pretty husky fella? I've not seen many cars that required removal of the head surround to get out, and certainly not cars w/ such a generous cockpit opening like your car (or mine)...
    I drove a car over the weekend that had really neat sliding latch type affair, no loose parts, just align the hole of the latch over the ball/stud on the bodywork, and then slide the latch back to capture the ball stud. The onlt reason to remove the collar on that car was to access a plate to remove and refuel.
    I'll look for an image on Pegasus or McMaster and post it up.
    This method is so cool I'll be adapting it to my RFR!
    Indiana
    Liked: 175
    Sometimes there's a good reason for doing this. I can't see to fasten my belts with the helmet and HANS on.
    Bradenton, FL
    Liked: 14
    Default Re: Stohr 2008 head rest /collar
    Who can? :what:
    -Head MRTI Indy Lights Mechanic: -Head SCCA USF4 Mechanic
    -Lead Cape Motorsports Mechanic: -Head PWC Audi R8 Mechanic
    -Lead IMSA LMP2 Mechanic
    atlanta, ga
    Liked: 136
    Quote Originally Posted by David Locke View Post
    "You must use The Force, David" OR Have a suitably hot chick on staff to do up the belts!
    Indiana
    Liked: 175
    She's tried, Glenn, but it's a long way from the side of a WF-1 to the bottom of the tub, and she doesn't have enough leverage for the lap belt.
    atlanta, ga
    Liked: 136
    Default I hear ya...
    Have you seen the adjustable "pull up" lap belts?
    In my FM days I could do it all myself, as soon as I got the VD RF99 FC/ FB car it was "Hellllllp, anyone, gimme a hand, Pleaaaaaaaaaase!"
    New Jersey
    I agree, I get in the HAN's on, helmet off, so I can see what I'm doing getting belted in. I have no problems getting my helmet/tethers on.
    NC
    Glenn, have you seen Vic and Cory try to get me strapped in,, its like a chinese fire drill.... and as for me getting out ,,, the surround has to go. We use the fasteners with the wings
    Australia
    Hi Glenn
    Not a chance of getting out even with my helmet off, i'm not fat in any way and have a 33 inch waist, but still get stuck all the same. the cabin has plenty of room, but the head rest constricts the exit space.
    If you can get some photos that would be great.]
