I am doing the mockup of the BMW S1000RR engine in my conversion FB, so far no problems, no cutting or welding. It is almost as if Novak build the chassis to accept a wide array of engines.
The engine is 2 full inches shorter than the 05 GSXR that came out of the car today, the bimmer engine drops right in and centers perfectly in the bay, the output sprocket lines up with the rear sprocket, no problem. I weighed the bmw engine and it is 12 pounds heavier than the gixxer. There is extra weight above the head due to the electric throttle bodies, the airbox is super complicated with velocity stacks that move up and down and has injectors built into it.
The next step is to make engine mounts, that will be hard since I've never done that. In theory the engine mounts very similar to the gixxer so it won't be really hard to figure that out.
By the time I'm done with the engine mounts and exhaust, I am hoping that the SCCA Fastrack finally states what the ECU rule will be for the future. I have seen a lot recently about the ECU, anybody knows whats going to happen there?? Any ideas.
Regards
Marchand Juan
