Results 1 to 20 of 20
Thread: Mission #3
    San Antonio, TX
    Liked: 37
    Default Mission #3
    The new Mission is starting to look like a car. 80% done, 50% to go....
Name:	Rtside-brake lines.jpg
Name:	Rear view1-2-14.jpg
    Plainfield, IL
    Liked: 190
    Greg,
    The car really looks great. Real craftsmanship in your assembly . I really like the Mission and the work that Jim Nash has put into the car. I'm sure your going to be very happy with this new car. Hope to get to see it run this summer.
    Bill Bonow
    San Antonio, TX
    Liked: 37
    Thanks Bill, this car has been such a pleasure to assemble; easiest kit I've ever put together. Jim really has an attention to detail and is superb to work with.
    My shocks are on the way, engine and exhaust will be soon. Some fabrication (my choice) of some panels in the seating area will be next. After that the engine plumbing and electrical. I'm targeting early spring for the first shakedown run here in Texas.
    My best wishes to you all up there in the deep freeze. 18 below this coming Tuesday? Yikes.
    Greg
    Shelbyville, TN
    Liked: 94
    Default Mission
    Looks awesome..... One thing though, I would move that transponder behind the beam for protection.
    Scott
    Administrator dc's Avatar
    Chicagoland, Illinois
    Liked: 1417
    Beautiful! I can't wait to see more of this car. Jim's design is one of the prettiest FSTs out there.
    Rochester, NY
    Default Workmanship
    Jim Nash design flair and careful construction and your workmanship make this car a standout. While you can't tell from these pics the bodywork is exceptional too.
    Greg let me know what shocks you finally settled on.
    Plainfield, IL
    Liked: 190
    Greg,
    Any ideas on color(s) the car will be painted? That Jim Nash / Mike Devins body has a lot of good potential for color(s). Frankly, we've seen too many orange Missions
    Bill Bonow
    Los Angeles, CA
    Liked: 290
    Two questions:
    1) The lower front shock/push rod mount on the control arm: Is it welded in place to prevent it from rotating?
    2) The rear suspension lower push-rod mount on the axle: What is the purpose of below the axle center line mounting position? Is this supposed to provide some kind of better mechanical advantage?
    Plainfield, IL
    Liked: 190
    Brian,
    #1 Those lower mounts are bolt on with a single nut. They don't move. That style are pretty much universally used on cars with inboard front shocks
    Don't know the answer to # 2
    Bill Bonow
    Senior Member rave motorsports's Avatar
    Murfreesboro Tennessee
    Default Looks Great Greg
    Car is looking super Greg. Just a reminder we are planning an FST race at Motorsports Ranch in Fort Worth this season as well as a couple at Hallett. Chuck Singletary and I are aware of the huge potential for the FST class in the Texas area and want to provide an FST series that makes it convenient for all of us out here to participate in.
    Liked: 4359
    Brian,
    That is where the original BRD design had it using a clevis and the original VW flange hole.
    San Antonio, TX
    Liked: 37
    Default Shocks
    Robert,
    Fronts will be from ARS per Jim Nash's specs. I found a good deal on a Penske 8760 and it is currently on its way to Stimola for a check out/revalving, etc.
    I am most grateful to you, Bill Vallis and Greg Rice for the info and advice.
    Greg
    San Antonio, TX
    Liked: 37
    Default Colors
    Bill,
    I've been thinking red, never had a red car. Too close to orange?
    Senior Member Jim Nash's Avatar
    Bloomington, MN
    Liked: 67
    Greg,
    The car looks like it is really coming along. It's a big thrill for me to actually see an MRC somewhere other than my own shop! Keep the pictures coming.
    Red sounds good to me.
    Senior Member AVR_Shane's Avatar
    Barrie, Ontario, Canada
    Liked: 200
    Any idea why the BRD isn't like that anymore?
    Shane Viccary
    #27 Citation-Zink Z-16
    San Antonio, TX
    Liked: 37
    Default Mission #3 More Pics
    Front suspension is now assembled, still checking clearances, bolt lengths and a preliminary alignment will be next. Jim has given me some car specific specs to work with as a baseline.
    Also, a seat shell I've been working on prior to the bead/foam seat insert. Still haven't decided which system to use.
    Body test fitting is in progress.
ID:	43556   Click image for larger version.
Name:	Front susp left side.jpg
ID:	43557   Click image for larger version.
Name:	Seat shell center.jpg
Name:	Seat shell rt side-shifter.jpg
ID:	43559   Click image for larger version.
Name:	Body fitting Left side.jpg
ID:	43560   Click image for larger version.
Name:	Body fitting Rt Side.jpg
    Southeast MI
    Liked: 254
    Wow! That car is looking pretty. Good luck and keep up the good work. I guarantee you'll enjoy this car
    Plainfield, IL
    Liked: 190
    Default Mission # 3
    Greg,
    Any updates on the project/car?
    Bill Bonow
    San Antonio, TX
    Liked: 37
    Default Not ready for the track yet....
    The car is just lacking paint, a throttle cable, the usual odds and ends and, sadly, an engine. Hopefully Jim will come through soon, but this year is becoming a washout.
    Default Texas racing
    Greg
    Both Chuck Singletary and I had a gentleman from the Dallas area that may want to join the FST ranks next season stop and talk to us this week. We offered a car for him to do schooling and to help him along the way. We would love to have a Texas race next season so let's get a dialogue started about that possibility.
