I'm building a Lola T-492, and have a question about the oil plumbing. The oil tank has two inputs, upper corner on each side of the triangular tank, and they are 1/2" tubes, so I would connect to them with -8 line. The oil pump has two scavenge sections, so two AN-10 outputs. I was planning on building a manifold to tie them together into one -10 line, to the oil cooler with -10 in and out, and back to the tank where I would use a second manifold to split the -10 line to two -8's into the tank. Does this seem reasonable? Is there a more standard way to deal with two scavenge sections and two tank inputs?
Tank also has two vent connections on top, and a -10 tube output on the bottom, along with a temperature port and a drain port.
Thanks, Brian
