I replaced the 6 year old VDO pressures sensor (150psi, #360-430) that is recommended for use with the AIM MyChron3 Gold dash I have as I suspect it may be giving me false readings. At rest it reads -4lbs so that alone warrants investigation.
I replaced it with an identical VDO unit except it is 0-80lbs (#360-410). Now when I start the car the oil pressure reading goes to 125.5lbs and pegs (it was 56lbs the day before with the old sensor, same starting temps). Ellen at Veracity opined she saw no reason the 0-80 wouldn't work fine and I elected to go that way as I normally don't see pressures much above 55lbs (cold morning startup) and it seemed the sensing spread was more appropriate.
As near as I can tell it is not possible to calibrate the Oil pressure sensor as when I go into the calibration area the sensor does not show up. I pursued that path when the dash started to read out -4lbs a while back, a dead end.
Any ideas what I am doing wrong?
Tom Duncan
RF98K VD FF
