Results 1 to 14 of 14
Thread: Shock tuning
    Fallbrook, N. San Diego Co.
    Liked: 9
    Default Shock tuning
    My car seems to handle very well with the triple adj Penskes. I vary the high speed compression dampening from the mid setting to min depended on how uneven the course surface. I leave low comp and rebound at what came on the car. I am looking for more info and someone to delve into the shocks and adjusting them for maybe better autocross performance. Any help or ideas?
    Mark
    Senior Member PCalhoun's Avatar
    Now in Greenville SC
    Default Anze
    Call Angelo Zarra at Anze Engineering. He trained under one of the best FF shock tuners there was Joe Stimola, whose shocks have won CM at least 3 of the past 5 years.
    http://www.anzesuspension.com/
    Peter Calhoun
    Motorsport Manager- Michelin North America, Inc.
    Swift DB1-86 FF1600 (bye-bye 3.12)
    2009-10 SCCA CM National Champions
    DFW
    Mark
    Guy Ankeny for west coast Penskes
    Liked: 9
    Quote Originally Posted by kjchristopher View Post
    Guy got back to me. He said he had no idea what kind of valving I might need. I e mailed the previous owner with Q's. Hope he gets back to me.
    Mark
    NY
    Liked: 127
    I work for Angelo at ANZE. We would be happy to help you out with whatever you may need.
    You can reach me directly at wvelkoff@anzesuspension.com
    Will
    Will Velkoff
    Van Diemen RF00 / Honda FF
    DFW
    Mark
    That's a very odd response.
    Liked: 9
    Guy also said he could change the oil and put them on his dyno.
    Mark
    DFW
    We (mostly Marshall) ran numbers and printed out a desired plot for my A mod shocks. I asked Guy if he could help. He said yes, but asked that I go with what he felt I needed, having watched the car for a year. He said that if his hunch was wrong, he'd fix them for free to what ever I wanted. I said sure.
    When I got the shocks back, they came with dyno charts that looked just like the ones we (mostly Marshall) came up with. Seems his "gut" pointed the same direction as the spreadsheet (which he didn't have).
    Liked: 9
    Could I see what "ran numbers and printed out a desired plot" looks like?
    Mark
    DFW
    Mark
    I don't think any of it would translate to your CM car. Unless you plan on running springs to compensate for 1000# of downforce.
    Member Robert Puertas's Avatar
    Irvine, CA
    Mark,
    In case you're looking for the basics, here's a decent article on shock dynos and force curves:
    http://www.roehrigengineering.com/Te...ome%20from.pdf
    Liked: 9
    Quote Originally Posted by Robert Puertas View Post
    Mark,
    Thanks, Robert.
    Mark
    Liked: 9
    Wow, 1000lb. No problem as I have found them elsewhere.
    Mark
    Los Angeles, California
    you can plug some numbers into something like this to get you started.
    http://farnorthracing.com/autocross_secrets16.html
