Hey guys spread the word if you know anyone wanting to get into racing. This package really would be ideal for a first race car racer. Selling everything not just the car. Firman specific spares must go with the car, other things like scale pads, generator, etc. can be negotiated out of the deal for a reduced price.
See full description here http://www.volomotorsports.com/firman.htm
Pics of some stuff here: http://vanvalks.smugmug.com/FirmanF1000
What we've got for sale here is much more than just a race car. We are selling all of our racing setup and equipment. Everything from our computer scales and scale pads down to our generator are included. The idea is that someone can buy this setup and head out to the track and start racing next weekend with minimal additional expense. Our spares package is very extensive and was purchased and maintained with the goal that no breakage should cause the race weekend to end early. You won't see many spare packages as comprehensive and complete as this one.
This Firman F1000 is an 09 chassis which was first raced in 2011. It was the 2nd chassis to have built in Geartronics mounts and has been updated to 2013 specs except for the narrower side pods. The car saw 4 to 5 race weekends in 2011, 1 or 2 in 2012, and 2 in 2013. Included are 2 motors which are both 08 Suzuki motors which have always been refreshed when needed by George Dean. The motor currently in the car was refreshed by George and put in the car in August 2013 and has been raced once. The spare motor has approximately 4 to 5 races on it since it's last refresh.
This is Rod Morley's firman. Those who know him know it's been properly maintained and well taken care of!
Car Features:
Chassis first raced in 2011, less than 15 races total
2008 GSXR-1000 Motor w/ 1 race
Geartronics no-lift shift system
Quaife LSD Differential
Floating rotors upgrade
Ohlins TTX-36 shock upgrade
Aim Evo 4 data w/ GPS
New development rockers
Updated to 2013 race spec (except for narrower side pods)
Electronic fire suppression system
Schroth safety harness
Lightweight lithium battery
Bodywork:
Complete spare nose & front wing assembly
Front cowl (used)
Racetech mirrors (new set)
Racetech mirrors (used set)
Alternate side pod vent covers
MKI Complete Rear Wing Assembly
Front floor extension (new)
Front wing end plate LH (used)
Front wing end plate RH (used)
Rear floor diffuser wings
Barge board LH (used)
Barge board RH (used)
Barge board LH (new)
Barge board RH (new)
2x Front wing adjustable wing (used)
Rear side pod support hangers (new)
Front side pod support hangers (new)
Nose crush bos (new)
Lower element rear wing (new)
Camber plate rear LH MKII
Camber plate rear RH MKII
Front upper element rear wing MKII (new)
Rear upper element rear wing MKII (new)
Rear wing end plate LH MKII (new)
Rear wing end plate RH MKII (new)
Rear wing end plate MKII (used)
Front wing shoes
2x rear wing support plates (used)
Roll hoop cover (used)
8x rub blocks (new)
Jabrock wood floor
Brakes:
Full car set Hawk Racing brake pads (new)
1 axle set AP Racing brake pads (new)
Original slotted non-floating rotor set with minimal use
4x Brake caliper pad pins (new)
2x replacement caliper pistons (small) (new)
2x replacement caliper pistons (large) (new)
2x front caliper rebuild kit
2x rear caliper rebuild kit
Girling .70 master cylinder (new)
Girling .75 master cylinder (new)
Cooling:
C&R custom made water radiator (new)
Firman water radiator (new)
Oil radiator (new)
Various radiator caps
Radiator repair sticks
Drivetrain:
4x16 JT Sprocket front sprocket (new)
4x17 JT Sprocket front sprocket (new)
2x15 JT Sprocket front sprocket (new)
Original open differential
DID ZVM-X 230 link chain (new)
DID chain tool w/ many master links
47 tooth 2-piece rear sprocket (used)
50 tooth 2-piece rear sprocket (used)
45 tooth 2-piece rear sprocket (new)
49 tooth 2-piece rear sprocket (new)
2x 48 tooth 2-piece rear sprocket (used)
46 tooth 2-piece rear sprocket (new)
51 tooth 2-piece rear sprocket (used)
Rear axle tripod bearing (new)
Rubber axle boots (new)
Driveshaft RH (new)
Driveshaft LH (new)
Cable lube tool
Aluminum bearing carrier (used)
Electrical:
Quick connect rolling jumper battery
2x GDRE flashed ECUs
GDRE prepped wiring harness
AIM channel expansion kit (new)
02 sensor (new)
8x coil packs (used)
2x Geartronics gear position sensor (1 used 1 new)
Oil pressure sensor (new)
11x NGKCBE4A spark plugs (new)
Relay for shift system
Fuel system:
Powerline inline fuel filter
Edelbrock fuel filter
2x fuel pressure regulators
Throttle spring
Miscellaneous:
Kestrel wind gauge
Lift strap for hoist
Nut and bolt bin (car specific bolts ordered in large quantities)
Nitrogen air cylinder 251 cubic foot (owned can be filled anywhere)
4000psi to 150 psi regulator
100ft premium air hose
VIO POV camera
Brennar fabrication rolling car hoist
Brennar fabrication rolling car stand
Suede wrapped 2-piece driver seat
Motor:
2008 GXS-R1000 motor, throttle body, slave cylinder, etc.
This motor has a few races on it, still in good condition.
All motor refreshes have always been done by George Dean
Setup and Scaling Stuff:
Longacre Roll-off Levelers (part no. 72905)
Longacre Computerscales DX & Rolling cart
Block gauge set
Custom F1000 specific aluminum alignment bars for setting toe
Custom camber tool
Suspension:
2x variuos stiffness rear sway bars
2x variuos stiffness front sway bars
500 lb Hyperco springs
600 lb Hyperco springs
700 lb Hyperco springs
800 lb Hyperco springs
900 lb Hyperco springs
1000 lb Hyperco springs
1100 lb Hyperco springs
1200 lb Hyperco springs
1300 lb Hyperco springs
1400 lb Hyperco springs
2x front upper wishbone
Front lower wishbone LH
Front lower wishbone RH
Rear lower wishbone RH
Rear lower wishbone LH
Rear upper wishbone
3x front sway bar arm
Front pushrod
Previous generation suspension rockers
Suspension turnbuckles
Various eye bearings
RH rear steering bracket to upright
Front steering bracket to upright
Steering rod track rod
Wheels & Tires:
2 sets OZ Racing magnesium black wheels (1 set on the car)
1 set Hoosier R35A 3 heat cycles, purchased 8/13
1 set Hoosier R35A 2 heat cycles, purchased 8/13
1 set Goodyear intermediate groved tires
1 set Goodyear rain tires
1 set Jongbloed wheels for rain tires
Spare halves for Jongbloed wheels
Chickhawk tire warmer full setup
Dedicated generator for tire warmers and heavy duty custom extension cords
Wheel lug nut
4x replacement valve stems
Wheel spindle
Wheel bearing
Printable flyer attached below. Thanks for looking!
