    Houston Heights
    Default Extra hole in wheel?
    Can anyone educate me as to the purpose of what appears to be an extra valve stem hole in an OZ wheel from a 2002 IRL car? There is a normal valve stem hole towards the outer edge of the wheel, but then there is a second hole, 180 degrees around the wheel, but very close to the middle of the wheel centerline, drilled not tapped. Sorry I don't have a picture. Three of the four wheels I'm restoring for a display car have this hole plugged with a nut, bolt and gaskets, but the fourth one is missing and I don't know where to get another plug. Can anyone point me to a source for these plugs? I'm also curious what the original purpose was for the hole... pressure relief valve, pressure monitor? Thanks.
    Contributing Member BWC54's Avatar
    Big Canoe, GA
    Liked: 36
    Could be for nitrogen purge.
    Crossle 32F, Piper DF5 Honda
    Cleveland, OH
    Liked: 111
    Or pressure bleeder if Indy ever used those.
    Liked: 285
    Could also be a mounting stud for a wireless pressure/temp sensor.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Liked: 1879
    Wireless pressure sensor as David stated.
    Member JohnCummiskey's Avatar
    Indiana
    Yes this hole is for the TPMS sensor. If your just using the wheels for a show car the any bolt with a o ring will do. If your in Houston Foyt would have the proper plug if not I have a bunch.
    Houston Heights
    Default Problem solved
    Thanks, guys. The local race prep shop had everything needed. The freshly painted wheels look great and now I can roll the car around since all four tires have air.
