Results 1 to 13 of 13
    Member wink31's Avatar
    evergreen, co
    Liked: 31
    Default Lime Rock Speeds
    Anyone have any data for a competitive vintage FF lap of the speed of fastest and slowest points of a lap at lime rock in mph? Where are those points? What's the speed of the most important corner at LR and which one is that?
    Thanks!
    Member greg V's Avatar
    Northeast CT
    That's one thing about LRP, .. there really is no "most important" corner. I could find a reason for every corner being the most important. But then again, I don't drive an FF car
    Northeast CT
    NY
    Liked: 127
    My minimum speed on a 57.9 second lap was 69 mph, max speed 120 mph. Best I've done in a draft is 124 mph at the end of the front straight, so gear accordingly.
    This is in a Kent powered Crossle 30F on Hoosier R60's.
    Hope this helps.
    -Will
    Will Velkoff
    Van Diemen RF00 / Honda FF
    evergreen, co
    Liked: 31
    Great info will. Would still like to hear for someone running dunlop threaded tires.
    Northeast CT
    I'm curious about this thread. What information is gained by the question and how will it be applied to your approach to the track?
    Tempe, AZ
    Quote Originally Posted by greg V View Post
    Thanks for the link. Not only was the Posey video worthwhile, I wound up following links to Skippy's "Going Faster" and a couple of other goodies. Good thing I had a few extra hours..
    Caldwell D9B - Sold
    evergreen, co
    Liked: 31
    I've seen several different gearing suggestions, but nothing very definitive. I can check some configurations and do some of my own figuring given my gear inventory if I know the speed range at the track. I guess I didn't realize it was so fast for such a short track. Can't wait to try it out at the Labor Day historics.
    NY
    Liked: 127
    It's a fast track..average speeds in the 90's depending how fast you are for a FF.
    Will Velkoff
    Mn
    Liked: 202
    Default Re: Lime Rock Speeds
    Greg... my guess... speeds provide basis for gear ratios to power band. Tire size part of same equation & to speed in turns...
    Northeast CT
    Thanks. Good to learn from the open wheel guys, because these are things that the tin tops don't ask about really.
    Tempe, AZ
    Not a lot they can do about it with fixed ratios.
    Caldwell D9B - Sold
    Mn
    Liked: 202
    Well, then I quessed wrong
