    Hudson, Ohio
    Liked: 208
    Default Clutch Master Cylinder Sizing
    My clutch pedal on my vintage FF is pretty hard to comfortably push. I don't think there is anything really wrong with it but I would like to make it a bit easier to push.
    If I want to require less force to depress the pedal do I move to a larger diameter master cylinder or a smaller diameter?
    Yeah, I should know this, but...
    Thanks in advance.
    Ralph Z
    1968 Alexis Mk14 Formula Ford
    Smaller dia master will reduce pedal effort but you will need to depress further to achieve the same force at the calipers
    Liked: 610
    Common clutch master cylinder size on older F/Fords, was 3/4". This worked well with the standard OEM style clutch they were designed for.
    With the racing clutch, moving down one size to .70" should solve your problem, without making the pedal stroke too long.
    Apache Junction, Az
    Liked: 102
    x
    Last edited by Brian C in Az; 08.11.14 at 5:04 PM. Reason: mistaken for brake master discussion - oops
    Sagle, Idaho
    Liked: 180
    Default Bobbin?
    Another possibility is checking the bobbin/release bearing diameter where it meets the clutch cover face. On our car I found that I could reduce the diameter over 1/2", reducing the force required to release the clutch, but taking a tad more travel at the pedal as well... We did have to make this part as the bearing is a set diameter.
    Now it acts more like a normal clutch than the "on-off switch" feeling most racing clutches give.
    May not work on all chassis but did for us.
    Our M/C diameter is already .70".
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
    Hudson, Ohio
    Liked: 208
    Yes, we know that our release bearing diameter is quite large and that is the actual cause of the problem. A temporary and easier fix is to change the MC. The final solution is a new release bearing which means splitting the car. Good winter project.
    Ralph Z
    Sagle, Idaho
    Liked: 180
    Winter: That's when we did it
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
