Results 1 to 38 of 38
    Member igino's Avatar
    Palo Alto, CA
    Default Bending floor pan
    Folks -
    Need some tips from someone that is pretty handy with sheet aluminum. I want to bend a floor pan for my frame (pictures attached - obviously not finished). It will bend up about 2" on both sides, and attach with dzus tabs. As you can see, the sides of the floor are narrow near the front and then angle out and finally straighten out in the back area. I would really like to avoid cutting and welding it, as I think that will look crap compared to some time invested in shaping it nicely.
    Here's my question - can I massage this in on a large box-pan-brake? A little here, a little there, a little more here, etc etc?
    Any other good ideas you can think of?
    Last resort is to make a male mold and hammer it around that - but with all that effort I might as well make a composite floor. Done that before - more a lengthy than difficult project.
    Also - I should mention that I don't want to leave it flat and attach it on the bottom of the car because I don't like the idea of the dzus heads sticking out the bottom of the car. For several reasons.
    Thanks!
    -Igino
    Why do you want a removable floor pan? A bonded and riveted floor pan adds a large amount of stiffness to the chassis. I would think a floor pan attached with a few Dzus fasteners would also be much more likely to be ripped off if it catches on something like a curb or dirt mound in an off track excursion.
    Chris Ross
    Palo Alto, CA
    Thanks Chris -
    What do you mean by "bonded"?
    You bring up a good point about the stiffness of the chassis. I was thinking something closer to ~20 dzus tabs. That being said - there would be less slop around the rivets. Good point.
    My main consideration is that on my current car I have often wanted to be able to take off the floor for cleaning, plumbing, modifications to other parts etc. It would be a huge maintenance advantage to be able to easily take off the floor.
    Thanks!!
    -Igino
    Liked: 304
    Igino,
    Search the site for "floorpans" or "bellypans" and you will get plenty of information on installing floorpans. Pay close attention to what Mr. Lathrop has to say. Typically recommended is to bond the pan to the bottom frame rails with a special glue and rivet with a pattern instead of a straight line of rivets. It adds strength to the frame. A "removable" pan may well get removed in an accident, not a desirable outcome.
    Some people (like me) have welded the pan to the frame. Continuous weld around the perimeter and to bulkheads.
    Regards,
    Barry
    Vancouver BC
    as nice as it would be for maintenance, I'd put some serious thought into making it a bit more permanent.. Bonded (there's a special adhesive for that sort of thing..) and riveted would still be somewhat non-permanent, but infinitely safer!
    I don't think chassis stiffness is a big deal in a zero roll FV, but the less potential for my arse to drag on the asphalt, the better
    Palo Alto, CA
    Guys -
    Thanks a lot for all the info. Definitely opening my eyes to different methods of floor attachment I had no idea about
    Welding the floor seems a bit TOO permanent to me. I'm the kind of guy that really enjoys garage time. I don't think I've gone to two separate races without making a change to the car.
    I'm trying to design this chassis so that even if the floor came completely off I would still be OK - apart from puncture wounds....which is what is giving me pause. This PRC stuff definitely seems advantageous on that front.
    Just thinking out loud - and also thanks for the tips so far.
    Senior Member smsazzy's Avatar
    Seattle
    Liked: 16
    Page 310 of the GCR - section F: "Any undertray(s) between the axle center lines shall be rigidly attached to the frame....."
    If I were a tech inspector, I'm not sure I would consider temporary fasteners to mean "rigidly attached". I'm not a tech inspector though. :-)
    I would strongly advise against that though. Rivet the floor at a minimum.
    Senior Member Jean-Sebastien Stoezel's Avatar
    Winnipeg, MB
    Liked: 15
    Even though I do not think a removable floor in the cockpit area is the safest solution I do not think it is illegal.
    Several cars have removable floors or undertrays between the axles centerlines, mine has one in the engine bay. It's held in place by dzus fasteners.
    In essence then what is proposed here would seem legal and already applied.
    Quote Originally Posted by smsazzy View Post
    Western Canada Motorsport Association (WCMA)
    FV #0
    Palo Alto, CA
    Thinking about this some more - Just for arguements sake, what failure would you expect to see from an adequate number of steel dzus tabs that you would not see from rivets? This is not rhetorical - I have comparatively precious little experience with either compared to the brain trust here
    Seattle
    Liked: 16
    Quote Originally Posted by jstoezel View Post
    I'll give you that.
    Seattle
    Liked: 16
    Quote Originally Posted by igino View Post
    I believe my floor on the Vortech had about 200+ rivets. I suspect those rivets were about the same diameter as the little spring the dzus grabs onto. So if you put 200 of them on there, sure, I guess the material would be the same.
    However, check with an engineer regarding the forces on the material. I would suspect the rivets in tension woyuld be stronger than the sheering force on the springs. Not to mention that there would be a level of "springy-ness" to those springs; far greater than the springy-ness of the rivets. Whether you could perceive it or not, it is there. That would lead to eventual fatigue.
    Lastly, ultimately, each dzus is held on by what? Two rivets? So let's assume for a moment that the dzus is actually stronger than the rivets. Unless you have a huge abundance of them on the car, you are still ultimately held on my two rivets times the number of dzus fasteners.
    Those would be my thoughts after giving it about 15 seconds to contemplate before my response.
    Liked: 304
    Dzus fasteners are not rigid. By definition there is some play. Because there is some play, in an accident the force is going to get applied to one or a few dzus fasteners, popping them, them load transfers to the next one/group and so on. Until the pan is left flopping around or worse, comes off completely creating a hazard for you and your fellow racers.
    There is probably a reason the pan is not treated as bodywork, and that no one else is doing this...
    Question, is this a FV or a FST? looks like it could go either way.
    Palo Alto, CA
    I think you nailed it here, with the force getting applied one by one to the dzus fasteners. Rivets it is! It's an FV.
    Now if someone will PLEASE tell me how to bend this darn floor pan - still can't find info on the bending operation itself =)
    Lexington KY
    Liked: 50
    Igino,
    If you are going with the bonding and rivet route, I am not sure why you want to make the bends you describe. It is a fine idea to have a small lip 1/4-1/2" at the front and sides, just to keep things from grabbing the pan between the frame and pan. But, all the bonding and riveting would be on the bottom of the car. Use steel, blind flathead countersunk rivets. Usually every 1" or so, staggered (not in a straight line. There are several good bonding epoxies. (2 part, 3M etc.).
    You can find several different bond type, but get a 2 part that has at least a couple houra of working time. (even 24 hr is fine) Fit your pan to the car with a couple C-clamps. Then start drilling the holes for the rivets. Drill a few at each end and side of the pan. Place the rivets in the holes to hold the pan in place, (or use cleco fateners) while you drill the remaining rivets. When complete with the drilling, countersink the holes, remove the pan, mix the bonding material and spread it on the bottom of the frame. (if the frame is painted you should remove the paint.) The bonding material goes a long way, Then place the pan and start installing the rivets. Hopefully you have an air riveter. Otherwise you will destroy your wrist and hand muscles after the first 50 rivets. .
    You will not lose your pan. If you do go off and drag the pan heavily, you can just inspect and replace rivets as needed. This is the tried and true method. It will be many times stronger than a dzus held pan. And as pointed out here, the dzus' are not firm and will be moving constantly on track and wear will be significant.
    859-252-2349 or
    859-339-7425
    http://www.sracing.com
    Palo Alto, CA
    Quote Originally Posted by sracing View Post
    Igino,
    Thanks Jim -
    I CADed the frame and did analysis on it assuming that I would use tabs for the floor pan attachment. I'm a little hesitant to drill ~200 holes into the bottom of my frame now. Carol Smith would lose his sh** if i proposed that.
    I guess i could weld some strips along the bottom of the frame and rivet into those, but now my feet are gonna be scrapping them every time i get in and out of the car.
    That's why I wanted to bend up the sides, and attach them vertically. Incidentally this puts all the rivets in shear strength doubling their strength, which would be nice too.
    Lexington KY
    Liked: 50
    Igino. Ok. (But what did C. Smith know about FV ) Yes, riveting on the sides would work (with bonding). But, it's a lot more work..
    859-252-2349 or
    859-339-7425
    Palo Alto, CA
    HAHAHA - good point. He probably thought it best to leave FV to the experts
    Thanks again for all the help - i'll churn on this and let everyone know what I come up with.
    Many formula cars use a square or rectangular shaped tube for the bottom frame rails to give large amounts of surface area for the bonding and riveting process for a floor pan. I noticed from your photos that the bottom rails are tubular. To get the necessary surface area for the bonding to be effective you would need to roll the floor pan around the sides of the tube like you are discussing or weld on some flat strips. Rolling the floor pan sounds like a lot of work and tough to do it where the floor pan is tight fitting to the shape of the tube so the bonding is effective. That still won't solve the issue of bonding the floor pan to the various cross members. I would look at welding a small strip to each tube to give you the extra bonding surface you need as well as giving you the width to do a staggered hole pattern. The staggered hole pattern will increase the spacing between the rivets that are in the frame tube itself. Read through the couple of lengthy threads on here about doing floor pans.
    Chris Ross
    Schellsburg, PA
    Liked: 115
    Default Floor Pan
    Just my two cents worth. A someone that has had a floor pan roll up like a sardine can I can say the more attachments the better. Regardless of how you attach the floor pan, you need a lip on the front to prevent (in the event of an agricultural experience) the pan from catching in the dirt. I've had more than one engineer tell me that structural rivets are the way to go. If/when you hit something hard the rivets will give way, but will help dissipate the energy. Better the car than your body. The last time I replaced my floor pan there were 188 rivets and I used countersunk rivets. I dragged my frame in the living room (I wasn't married at the time) set the frame on horses drilled, countersunk and de burred to Speed Channel for more than a few nights. An air operated pop rivet gun from Harbor Freight makes short work of the riveting. Bonding is also a smart move. Again, just my 2 cents
    Administrator dc's Avatar
    Chicagoland, Illinois
    Liked: 1417
    There is a very old but still relevant article written by one of our "no longer racing" forum members on bellypans to be found here. Has proven to be enormously useful in the past to many ApexSpeeders.
    Liked: 304
    I did not notice... But I see it now.
    Bending a single pan to match the shape of your bottom tubes (since they are not straight) and curve the bend to match the curvature of the tubing is going to be, uh, difficult (IMO).
    Plus, with a single piece pan you will get no bonding (not enough surface anyway) at the cross pieces which also appear round.
    I think it would be near impossible to do that and achieve a tight enough fit for bonding the pan to the tubes. (also, don't forget the 1" max bend in the rules which I believe applies here)
    If it were me, I'd weld it on. My second choice would be to weld 1" flat strips around the inside perimeter to permit the bond and rivet technique.
    A third choice would be to weld steel pans at the front and under your but area, then cover the whole thing with a riveted aluminum pan to close the gaps. (see Mr. Davis for an example http://wedgeracing.com/fv2008/index.htm scroll down near the bottom)
    IF you should decide to weld, go easy. Tack in place, then weld only short sections at a time. I welded no more than 3/8 to 1/2 inch, then moved to the other side, working my way around the car. This minimizes the heat and any warping of the frame. I had zero warping of the frame when I did mine.
    A few pics,
    First is finished pan (curved 1". 0.063 CM steel)
    Second shows the pan held down with nylon straps which did not get hot enough to melt as I stiched along
    Third is just a close up of the weld (notice the paint which did not get hot enough to bubble)
  22. #22
    Liked: 1880
    Thanks Jim -
    I guess I could weld some strips along the bottom of the frame and rivet into those, but now my feet are gonna be scrapping them every time i get in and out of the car.
    Your proposed attachment method is not legal - the fasteners on the sides are more that 1 inch above the lowest point of the floorpan ( rule FCS 9.1.1.8.F.)
    Every FF, FC and FB out there has their pan riveted and bonded to the square bottom tubes ( at least the intelligent manufacturers), and some have started adding in the 1" strips to the inside edge of every bottom tube so as to add extra bonding area. ( and then, some guys have welded their pans into place). This not only adds a lot of torsional stiffness, but it also massively increases safety. The real strength and safety is in the bonding, not the rivets.
    Attaching to the side in the manner you describe will not only be a nightmare ( to get the pan curled correctly to fit nicely around the lower tubes and up the sides), but will be a huge decrease in the safety compared to a bonded pan.
    Forget what you originally thought of doing and do the job correctly. Read AND FOLLOW the directions that Tom Johnson wrote up that Doug Carter referenced for you.
  23. #23
    Palo Alto, CA
    Well, yeah. That was why I originally posted.
    Prolly just going to weld it at this point. Then if something goes wrong down the line change all the bottom tubes to square tube. Or I'll just do that right now. Not sure.
    Thanks for the photos.
  24. #24
    Liked: 304
    the joys of working late... You're welcome.
    The main reason for posting the photo's was to show you that the welding can be done without excessively heating the tubing. I would finish all the tubing welds first, the weld on the pan. Where I think you *might* have an issue is welding the round cross members as it is sometimes difficult to get into a confined space and you have little to weld to. It took me most of a day to weld the pan, but I'm a slow welder.
    My opinion, I would leave the round tubing at this point, drill 1/4 inch holes about an inch apart in the pan where the cross members are located and do rosette welds there. Or if you're really good maybe you can get the pan welded to the members OK. The hardest part for me was welding the cross members. They are curved and the welds had to be done on the inside. I had a hard time getting close enough through all the tubing to "see" the weld well. I can weld pretty good when I can see (I use reading glasses for this). Next time around I'll have to have something that magnify's at those distances.
  25. #25
    Senior Member AVR_Shane's Avatar
    Barrie, Ontario, Canada
    Liked: 200
    Carol Smith also said that Formula Vee's are not real race cars...I think a few people in this forum might disagree with that statement!
    The only reason you might not want to weld a steel floor to the frame is because of weight. Depending on the surface area of the floor, you would be adding significant weight compared to aluminum. You can use a high strength aluminum (6061 would do). If bonded properly with stainless steel rivets, it would be plenty strong enough.
    Shane Viccary
    #27 Citation-Zink Z-16
  26. #26
    Chicago
    Liked: 15
    I replaced mine a few years ago and the Clecos were worth every penny. You can temporarily install the pan and verify accuracy and alignments.
    Additionally I would encourage you not to dzus fasten the floor pan.... if that was a good idea you would see it on all our cars.
    As for the bends, you can purchase a small brake at Harbor Freight to do it, worked for me.
  27. #27
    New Jersey
    It may even work to do the rosette welds mentioned on all the tubes, but leave the outside 1/2" long. Then after welding them, you could work your way around "rolling up' the sides with a hammer, and clamping them for stitch welds. Either that, or bend a 1/2" 90° flange first, which you can then stitch weld on the sides, and rosette on the bottom.
  28. #28
    Senior Member Jphoenix's Avatar
    Seattle, Washington
    Liked: 59
    If you don't want to buy an air-driven pop rivet gun, I used one of these to install high strength pop-rivets (Cherry-Max fasteners in the fuselage pan of a sailplane) and it worked quite well:
    http://www.amazon.com/automotive/dp/B003BZQ6KY
    Cherry-Max have a high stem-pull force with a steel locking collar. Compared to normal pop-rivets, they take more force to set and can strain the puller. I was able to pull up to 5/32" dia. Cherry Max, at least 500 of various 1/8" to 5/32" Cherry's and no sign of the unit failing or slipping. Works very well for normal aluminum or steel pop-rivets. Never used a hand puller again.
    Also, I agree with Cendiv, a bucket of cleco's are worth their weight in gold! Some of my cleco collection are 30 years old. My favorites are cleco clamps:
    http://www.amazon.com/Allstar-Perfor...ds=cleco+clamp
    Seattle, Washington
    Liked: 59
    Another clever trick when using epoxy-based adhesives for bonding, don't use acetone or MEK to clean up the drips and other sticky mess - before the epoxy sets, use vinegar as a solvent to clean any epoxy residue or drips, you will be surprised at how much better it works than checmical cleaners.
    Works for resin or hardener drips and spills as wells as the combined epoxy - after you finish gluing, dampen a rag in vinegar and clean up the drips, just don't let vinegar run into the bond line or it will degrade the performance of the adhesive bond.
    Syracuse, NY
    Quote Originally Posted by AVR_Shane View Post
    Conversely, part of the reason you may want a steel floor is because of the weight. If you're going to ballasting anyways, a steel floor pan is as low as you can get the weight, and does give a margin of safety over aluminum.
    Fortunately I enjoy my doughnuts enough that I don't need to worry much about ballast, and it's a pretty easy choice to go aluminum for me.
  31. #31
    Liked: 200
    Quote Originally Posted by Scootin159 View Post
    That's true, but it also possibly limits the different types of drivers that could drive the car in the future.
    If you are 150lb and plan to be the only driver in the car for a long time, have at her and weld it up!
    Shane Viccary
  32. #32
    Liked: 304
    The main reason for using steel in this case is to weld it. If only rivets/bonding are going to be used and weight is an issue then aluminum might be a better choice. In my case, the steel pan ends under the fuel cell and is al the rest of the way back. The difference in weight of 63 thou steel and 90 thou al was approximately 7 pounds as I recall. A 2 pound battery makes up for that over the original 11 pound one.
    If I were going al and rivets I would definitely weld the flat strips to the inside perimeter. I would not trust rivets only against the bottom of the round tubing and you really need the strips to bond (the round tube is only going to allow a straight rivet line and no bonding). Or I would use the Stevan Davis method in the link I referenced earlier, short pieces of steel welded in and a thin aluminum sheet to serve as a non structural cover.
    Just my opinion. By the way, congrats on building your own car. I'm sure you'll figure out what works best for you.
  33. #33
    Senior Member Doug FST 5's Avatar
    Cincinnasti
    Default bonded / riveted is a must
    Even with bonding and riveting you can lose the belly pan in a potentially dangerous way. In my years in FV I saw this happen twice. Once was an FV hitting a wall at Mosport. The frame racked and sheared the dozens of rivets. The other was a belly pan edge catching the ground after a flying FV dug in after a wild ride starting at the kink at Nelson.
    Doug FST 5
    ....yes the Nelson incident was mine...
  34. #34
    Palo Alto, CA
    Quote Originally Posted by Doug FST 5 View Post
    Doug FST 5
    holy moly! Do you have pictures of the damage??
  35. #35
    Cincinnasti
    Default no photos
    If we had photos I'm not sure where they are anymore - it happened 10-15 years ago. The car dug in while landing going backwards. The floor was ripped off to about where my knees were. My straining in the belts kept me from having a grass stain on my behind. Everything held in by the floor came out (fuel cell, fire bottle, battery). It was a mess - had it back in one piece two weeks later for the next National in the series of course.....
    Doug FST 5
  36. #36
    Liked: 4359
    Considering your rounded rails, welding the 1" strips to the inside of the rails will give you the flat surface you require for bonding and riveting. I see that, and welding a steel floor directly to the rails, as your viable options.
    Large sheet metal shops can use brakes and rollers to make almost any shaped floor you would want. The cost of the material would be a fraction of the total cost however.
  37. #37
    Adequate floor fastening is a nice thing...
  38. #38
    monterey ca
    Default floor pan
    Igino, its Slim, call me about this.
