    Member Cobra's Avatar
    Carrollton
    Default Svra @ cota 10/22-27, 2013
    I know of at least 11 Formula Fords I & II coming to this event from CVAR. Any other paid registrations form other Vintage Clubs? This is going to be a huge event!
    FFR Daytona, '12 F-250, Merlyn '71 Mk 20 FFI
    "Always do right. This will gratify some people and astonish the rest!" Mark Twain
    Jackson, Michigan
    Default SVRA Cota Nationals
    Anybody have an idea as to a starting point for Club Ford gear ratios for this event?
    Carrollton
    Default COTA
    Doesn't SVRA require Club Fords to run treaded tires? If that's the case, then CF's should be running similiar gear sets to FF's. COTA has some lone straights coupled with tight turns and a need to blast in second and third gears. You may wish to check with some of the SCCA guys that ran there last spring. I've heard that The Glen setup would be a good starting point.
