Results 1 to 6 of 6
    Midland, MI
    Default Mirror to Frame Bracket
    All,
    Looking for the name and/or number of the bracket used to lash a mirror mount to a frame tube as shown in the attached image. Searching McMAster-Carr and dang if I can figure out what to call it so I can find it...
    Chris Pruett
    Swift DB1
    SoCal
    Liked: 102
    Search for P clamp or loop clamp.
    I use two P clamps per mirror, so it is only mounted to the frame tube. That has several advantages:
    • Bodywork vibration does not affect the mirror.
    • When I bump into a mirror, the P clamps bend, so I can just bend it back into place.
    • The mirrors are mounted higher, so it is easier to keep track of what's going on behind me.
    • I can slide them anywhere along the length of the tube.
    • The wake of the mirror mount does not affect airflow on the body.
    Midland, MI
    Default Thanks Neil!
    Quote Originally Posted by Neil_Roberts View Post
    Appreciate the feedback! All set (for now )...
    Chris Pruett
    Swift DB1
    atlanta, ga
    Liked: 136
    Default Huh
    I thought those were "Adel" clamps... P clamps, who knew?!!
    Midland, MI
    Default Thanks!
    Chris Pruett
    Swift DB1
