I have a used "first generation" (rear pickup) generic wet pan that had the bolt hole ovaling done on a few of the holes which then allows the pan to be rotated 180 degrees and updated with the baffle plate and forward pickup.
I've been battling this thing since CoTA, and have had the engine out to reseal, but the problem persists: leakage and a mess to clean up after every session, as oil is coming out alongside the head of one of the pan attaching bolts.
I even cleaned it all up real good and coated the bolt threads, started the bolt, and coated the shank of the bolt as it was tightened. It still will coat the engine floor from sitting a few days, not to mention getting it hot and thinned out!
Does anyone run one of these pans, and experienced the above?
What did you do to fix the problem?
The only thing I see is to pull the pan, and weld up the affected hole(s) and redrill them so there is no longer any bolt hole ovaling.
Arrrrgh!
Coop
