Results 1 to 6 of 6
    Senior Member Jean-Sebastien Stoezel's Avatar
    Winnipeg, MB
    Liked: 15
    Default Transmission shaft play
    Hi:
    Could somebody have a look at this video and tell if this play is normal and within maximum tolerated?
    http://youtu.be/BXBUb5D7qbs
    I never noticed it before.
    I did find oil in the bell housing but it didn't smell like transmission oil. Sure seems like a bit of a gap at the seal when the shaft is moved around its axis.
    Jean
    Western Canada Motorsport Association (WCMA)
    FV #0
    Plainfield, IL
    Liked: 190
    Normal
    Bill Bonow
    Vancouver BC
    Both of my transmissions were like that too, so I hope it is normal
    Bellevue,Wa
    If you safety wire the two clips that hold the throwout bearing in place it may save you pulling a motor to put back in place. Easy to dislodge when installing a motor. Just wire the clips together through the coil in their middle,clearing the input shaft so it doesn't rib the wire.
    Winnipeg, MB
    Liked: 15
    Thanks for the replies.
    Picture?
    Quote Originally Posted by Bob Posner View Post
    Jean
    FV #0
    Lexington KY
    Liked: 50
    Quote Originally Posted by jstoezel View Post
    Hi:
    Yep, it's kind of like the starter motor. The shaft is actually held in place at that end by the gland nut in the engine,
    859-252-2349 or
    859-339-7425
    http://www.sracing.com
