Anyone using an AIM data system on a MC powered car? I have a Yamaha R6 in my F600 and am having trouble getting the RPMs to read out. My harness has a wire coming from the ECU with the RPM signal (I get a good reading when I wire in a digital tach), and I've wired it according to the data sheet (pin 5 of the RPM connector), but no joy. The system worked on the 2-stroke F500 setup with a clip on a plug wire, but this motor has coils on each plug (and an ECU output just seems like a more elegant solution... if it works).
Any wisdom provided would be greatly appreciated.
