Me and Cal.
Me and Cal.
Dave Piontek and me.
In this photo, is the drivetrain fully installed? I ask because I don't see any part of it.
With our Scorpion's bodywork, which is roughly similar to yours, we had to cut a big hole on top behind the main hoop for the MC. It needs the hole anyway to let the hot air out quickly.
Jim, does you engine sit up that high ,or is it to clear the intake stacks?
Dave
The MC is lowered as far as possible with a 2.5" tall oil pan but the top of the injectors along with the OEM air box still stuck up above the bodywork, thus, the need for the hole. The hole does help to exhaust the heat.
body #2 delivered today - #3 is in process
Here is Car #2 with the body in place. It dropped right on with only minor sanding to clear a weld. Fitting the body on the build table makes it very easy to set the correct heights for the side pods and nose. Jay is praying that it all fits together. Nice parts Mike!
Dave Piontek
Something else for your viewing pleasure. Not an F600 but related.
Jay I'm digging the Western Broncos shirt you are wearing, I thought you were straight up Wolverine..... cool.
What engine?
Stephen Adams
RF92 Van Diemen FFord
1980 Lola T540 FFord
I'm betting 1000cc bike motor and a full fendered body.
Marty
I thought 750 cc and heading to Canada...F4.
Stephen Adams
1000.
We just delivered Chris Ross's brand new Nova Blade to him today and he is on his way back to North Carolina. Complete car weight just under 600lbs without fuel or water.
Now back to prepping the other cars we are building. We should be testing with Calvin Stewarts car and ready for testing by the end of Feb.
Car #3 will be ready for pickup next weekend. Then on to building the next 2 cars of our 5 car production run.
Hi Jay. Do u haven all five sold...I know the first 3 are gone how about last 2 cars .are they spoken for?
Mo
Delete
Just a couple of additional pics.
Rear axle detail
Another
Chris & his new Blade.
I heard that Chris dashed into your shop between two nasty winter fronts - lucky guy!
We just refer to that period as "winter" in the northern states.
Front susp detail.
Dave's F600 headers just sitting in the engine compartment.
Yes Chris you are correct. The front suspension does not have shims for camber adjustment. I tried to do it with shims but could not due to package issues. The camber change for 1/2 turn of the outer rod end is .28 deg. Of course this camber adjustment requires an adjustment to the toe but we know how many flats on the tie rod gets the toe right where it is supposed to be so it is actually a very easy adjustment. There is an adjustment that allows for much finer camber adjustment but I think that about 1/4 degree is good enough.
Of course I could have designed it so that shims could have been used for finer adjustments of camber but I decided that it was not worth the extra costs.
In fact most current F1 cars also separate the camber and the toe but both are adjusted separately with shims for both adjustments.
I did not see the pressurized air intake on any of the bodywork. Is it still part of the design? Is there even the most remote chance that the bodywork can be adapted to my Novakar?
Ken Van Horn
We will have a purpose built airbox and will show it when we debut the car.
I really doubt if the body could be adapted, but we could try.
What about just adapting the air box to existing Novakars?
Chris Ross
OK, Jay, inquiring minds want to know where in NC Mr. Ross lives! As one of the Novakar "founders" (think, Epee – saw the pic of you and Dave – Man, we look old now!), I'd love to go see the latest from the brain trust.
Now that I'm finally getting my Prod car back together, you go and build some of these!
Rick
It is in my profile. Charlotte, NC.
Chris Ross
You would be a tough fit Rick. Possible but we would need to find every inch possible.
What's the overall length with the full body in place?
