Results 1 to 5 of 5
    Santa Cruz, ca
    Liked: 183
    Default HOWTo LD200 gear change
    Hey all,
    I recently picked up a formula ford, and while searching around for details on maintenance, I was surprised to see the lack of HowTo's for basic maintenance on the car.
    After working on the car for a while I can understand why this is. These cars are mostly hand built, anything you need you typically fabricate yourself, so most individuals who own and maintain these cars have a higher degree of mechanical abilities than other car enthusiast.
    Even still, some of these tasks can be a little intimidating for new owners, changing your gearset is one of those tasks that I was a little nervous about. I was lucky enough to be close to PorterRacing and I had Neil porter show me how to do the gear swap so I could get the car setup for autocrossing.
    I eventually got around to writing a blog post about it, you can view it here:
    HowTo change your gears on a Hewland LD200
    Any constructive comments are always welcome.
    Vancouver BC
    Liked: 470
    I made good use of your blog post, Chris...
    ...but one thing bothered me:
    Both you and the Hewland manual say to engage both reverse and first to lock the transmission, but you both show the 3rd/4th shift rod being the one you move.
    Anyway, thanks for doing the legwork.
    Alan
    Mn
    Liked: 202
    Default Re: HOWTo LD200 gear change
    :thumbup:
    Liked: 1474
    I don't think it matters which two you select, as long as you lock the geartrains to each other. I usually pick the first two that will actuate.
    Santa Cruz, ca
    Liked: 183
    Rick,
    I think you are right. unfortunately I can't find my Hewland gearbox manual at the moment to confirm which gear I am selecting. But as long as you double engage the output shaft your OK.
