    Silver Spring, MD
    Default AiM Sports SoloDL
    Anyone using the AiM SoLoDL data logger? Couple of questions if anyone has:
    1. Can you set a RPM shift light/indicator with it?
    2. Can it be mounted on the steering wheel without affecting the readings?
    3. Using a "cut down" wire harness can you still read the ECU air/fuel ratio?
    4. Is the stock connector cable from the ECU to the logger long enough to be used in a car application? Thanks. Ted
    Liked: 285
    The AiM Solo DL is not a dash, it's a lap timer, that can can log additional data channels.
    So...
    -- There are no shift lights, or RPM indication of any kind. The only way you will get RPM data is if the ECU data has an RPM signal.
    -- It will not work effectively on the steering wheel. It does have internal G-sensors which need to be mounted so that don't move relative to the car. Also, the GPS antenna (built-in) would not want to move.
    -- Depends on the ECU. I might assume you're talking about the Suzuki GSXR K-Line connection -- some folks cutting down the harnesses remove that wire (and the entire Diagnostic connector), and some leave it in place. I believe you would be looking for a gray wire with brown rings on it. Look at the AIM website for the ECU documentaiton, it has pictures of the connector and wires you would need for the GSXR.
    -- It's not a big deal to extend the wiring if necessary.
    David Ferguson
    Veracity Racing Data
    805-238-1699
    Londonderry, New Hampshire
    Liked: 101
    I thought you could use an RPM bridge with a DL?
    Lexington KY
    Liked: 50
    The Solo units do not have G-Sensors. They use GPS (and your ECM). They can be mounted anywhere and read accurately. No standad method of using anything except ECM and GPS data that I am aware of.
    859-252-2349 or
    859-339-7425
    http://www.sracing.com
    Liked: 101
    Quote Originally Posted by sracing View Post
    The DL does have actual G sensors in it (well, they both do but it's only turned on in the DL).
    I was thinking you can do RPM, but I think I'm wrong. You can do a LCU-One though.
    Liked: 285
    The Solo DL has the internal G-sensors enabled, whereas the Solo has the HW, but it's not enabled in the software (could change in the future, we hope!)
    Liked: 101
    The original firmware had them unlocked in the Solo.
