Results 1 to 37 of 37
    Senior Member Rondo's Avatar
    Delaware
    Liked: 22
    For Sale FF Performance Alloy Wheels
    Set of 4 5.5jjx13 FF Wheels. 4 inch offset, 3 3/4" bolt patterm, 5/8 diameter steel insert bolt holes. Some scratches and dings but fully useable. I used on 1985 Reynard. If interested can send detail pics of each one
    $Sold In mid atlantic we will figure out delivery
    Delaware
    Liked: 22
    new price - btt
    Liked: 3294
    Default I don't need these but...
    Is that offset correct? Seems like a lot for 5.5" wheels...
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 610
    Default FF Wheels
    Dave,
    That could be correct.
    They (UK) started using wheels (steel) that were easily available, and then an aluminum spacer to make up the difference to the offset they has used in the past. These alloy wheels were probably based on that combination.
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    Philadelphia, PA
    Default Offset?
    Maybe he meant 4" backspace.
    Liked: 3294
    Quote Originally Posted by sc94 View Post
    4" backspace also seems like a lot...
    Liked: 3294
    Dave,
    Yeah, that explanation makes sense. Thanks.
    Senior Member Neil Porter's Avatar
    Merced, Ca
    Liked: 19
    Default 4" back space
    Crossle 55, 60, and 70 FF used a 3.9 back space from the factory. They used a Fiat Panda hub/bearing unit on all four corners of the 55 and on the front of the 60 and 70 cars. The bearing huts wore out quickly and we have since make a custom replacement that has a bearing that is replaceable. In the stock hub/bearing units the bearing could not be replaced. Not sure if the bearing were why they used that back space or if it had something to do with the suspension design. Most likely it was the design of the suspension. Neil
    Liked: 433
    Maybe it was because the Fiat Panda was front wheel drive and FWD cars have alot more back spacing on the wheel than RWD cars.
    Graham.
    Australia
    Default Performance rims
    MSG sent
    Delaware
    Liked: 22
    On the reynard it used an aluminum spacer - at least 1/2 thick perhaps more. I never measured them..still for sale
    Park City, Utah
    For Sale Performance Alloy FF wheels
    Not to hijack Rondo's thread, but have a full set of the same wheels, new (never mounted)
    5.5 x 13, 3.75" OC, 4.00" BS, 9.5 lbs. $125 ea plus shipping
    Motorsport Services
    (435) 783-2933
    Delaware
    Liked: 22
    Lowered price
    Delaware
    Liked: 22
    Default BTT
    They need a good home!!!
    Australia
    Default Performance wheels
    PM sent
    Delaware
    Liked: 22
    Default Buy these wheels!!
    Reduced price...btt
    Marietta,Ga.
    Liked: 61
    These are the same wheels that were on the #40 Lola T440 I restored & sold while at the FF 40th reunion a few yrs ago and they worked fine on that car. Always thought they looked good, sorta Ferrari like.
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
    madison heights,mi
    Liked: 610
    Default FF wheels
    T440 Lola has a different bolt circle then the wheels that are being offered.
    248-585-9139
    Marietta,Ga.
    Liked: 61
    True, they were drilled for the older Lola bolt pattern diameter so don't buy them for a T440.
    Scott Woodruff
    Sequim, WA
    Liked: 46
    Default Help
    Well....O.K. for my benefit and the newbies: How is "back space" measured? TIA
    Liked: 433
    How to Measure Wheel BackSpace
    [/FONT]Items required to measure wheel backspace: Tape measure, Straight edge, Wheel w/o tire (preferred)
    The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel. This measurement is backspace. The above photo shows three wheels with 2",3", & 4" backspace.
    Cheers, Graham.
    Liked: 3294
    IMO, the diagram is confusing. The measurement needs to be from the wheel mounting surface to the inboard flange where the tire contacts the rim, not to the extreme rear of the wheel.
    Backspace is supposed to be a measure of wheel offset, which relates to the tire position, and should not include the thickness/width of the inner flange.
    Member iskifly's Avatar
    Littleton,CO
    Ok, silly question but will these fit a Crossle 50? I'm using Porter Racing hubs, they are awesome by the way, compared to the Panda hubs. Are they still for sale?
  24. #24
    Liked: 433
    Default Source
    This is where I got the back spacing info from.
    https://www.rsracing.com/tech-wheel.html
    Cheers, Graham.
  25. #25
    Liked: 3294
    Quote Originally Posted by Earley Motorsports View Post
    Cheers, Graham.
    Well, they have conflicting info there. They indicate, correctly, the wheel width, but then measure offset or backspace to the back of the rim. Again, the back of the rim has no direct bearing on the tire location, and, therefore, on the offset or backspace.
  26. #26
    Liked: 433
    Default Others
    Sorry Dave, no offense, Coker Tire and Weld Wheels just to mention a couple all measure back spacing from the outer lip also. They say the outer most surface.
    Cheers, Graham.
  27. #27
    Liked: 3294
    Cheers, Graham.
    No offense taken, but...
    They can measure any way they want (and it is, obviously, the easy way to do it), but the only way you will know the true offset and tire position is to measure the way I described. There are too many rim configurations and inner rim-edge widths/thicknesses for their method to be consistent, especially between rims from different manufacturers. What you want to know (for handling and tire clearance purposes) is "where is the tire with respect to the mounting surface," and using the outer edge will not give consistent results if the rim configurations are different. That is especially true comparing modular having rolled rim sections vs 1-piece cast rims.
    So to be precise and know exactly what you are getting, one has to measure the way I described. In the diagram below, the "B" dimension is the backspace.
    If you are looking only for rough values, the measurement to the extreme rear will give you that. However, with the close tolerances present in racing vehicles, it is, IMO, necessary to know those dimensions as precisely as possible.
  28. #28
    Sequim, WA
    Liked: 46
    Default Back space
    As Aristotle said: "when you debate me. First, please define your terms." Now we know.
  29. #29
    madison heights,mi
    Liked: 610
    Default FF Wheels
    BUT, backspace measured to the edge of the wheel does have a direct bearing to ordering wheels from a manufacture.
    248-585-9139
  30. #30
    Liked: 3294
    OK, Keith, answer me these questions:
    So, to get the offset and, therefore, the handling and clearance dimensions and characteristics you want, you have to know their rear rim dimension from tire surface to rearmost extension in advance?
    For street vehicles I have always ordered by diameter, width, and offset dimensions.
    For race vehicles I want to get the same 3 dimensions equal to my specifications.
    Why would a wheel maker, other than for ease of measurement, use a dimension that does not directly define the offset and the inboard (and outboard) extension of the tire?
  31. #31
    Mn
    Liked: 202
    Two different measurements. Back space for wheel. Back space for tire. I need to know wheel back space to clear calipers, etc. My tire back space for other clearances & tire - suspension geometries. All of which makes what little grey matter I have left, short-circuit
  32. #32
    Liked: 3294
    Well, I guess now everyone reading this knows the difference between the 2 measurements and can now make an educated decision when it is necessary!
  33. #33
    Liked: 433
  34. #34
    Sequim, WA
    Liked: 46
    Default stealing the thread
    Didn't mean to; hated to sound naive, now I don't feel so bad. Will make a good test question in the future.
  35. #35
    Delaware
    Liked: 22
    Sold - thanks Apexspeed
  36. #36
    Glendale, Arizona
    Liked: 501
    Actually, I am now thoroughly confused
  37. #37
    Park City, Utah
    For Sale 1 set available
    New, never mounted. $500 plus shipping for the set
    Motorsport Services
    (435) 783-2933
