Hello all,
environment;
Stohr Chassis, GDRE 2008 Suzuki GSXR.
Has anyone tried to control or reduce the heat generated by the header with a ceramic coating?
If so, did it work?
Did the coating effect the performance of the engine in a negative way?
Has the coating lasted?
Would header tape be as effective as ceramic coating?
or any other suggestions that may be able to reduce the heat in that small cavity area?. There is water return tube located on the lower bulk head firewall that runs from left to right. Currently it has a pliable silver thermal shield wrapped around it. Not sure if this enough. Any suggestions are appreciated. Thanks.
