I'm posting the current working draft of the rules underwhich Club Fords will participate in Monoposto vintage events. There are some important things to bear in mind:
1. This is a DRAFT document currently under review and comment. It WILL change before it becomes final.
2. The rules update for vintage FF's currently discusses permitting the recently approved crankshafts by SCCA. This is important since vintage FF's and vintage FF70 Formula Fords (Club Fords) will very likely run to the same engine rules.
3. The draft FF70 rules reference the Monoposto Rules which can viewed at www.monoposto.com
Please bear in mind that these rules are currently undergoing some minor updates, so some of the words can/will change before all this becomes final.
However, I have been getting emails from racers eager to see the FF70 rules, so here is the current draft version:
FF70 1973-1981 FORMULA FORD RULES
I. DEFINITION
A class for single seat, open wheel race cars manufactured and raced from 1973 through 1981 by private owners, using the standard Ford 1600 crossflow, pushrod engine. The following commercially constructed cars are eligible:
Alexis – MK23/24/24B
Caldwell – DL15FF and DL9 made in 1975
Crossle – 25F/30F/32F/35F/40F/45F – 1976 to 1979 (only the 32F/35F are eligible to use the Crossle wing tray)
Dulon – MP15/17/19/21
Eagel – DGF
Elden – PRH10/17/19/20,HD24
Elfin -620
Hawke – DL11/15/17/19
Hermes – 16/79, 16/80
Huron – FP2
HR2760
Image – FF2/2B/3/4/5
Javelin – JL2/5
Legrand – MK13/13B/21/27
Lola – T340/342/440/540
Meryln – MK24/25/28/29
PRS – RH02, 81F
Reynard – 73F/76F/77F/78F
Rostron – RT 77/78
Rowland – 1975/76 RP, RP 24-77, RP26-78
Sark 2
Sparton – FF78
Titan – MK8/9
Tiga – FF75F/76F
Van Diemen – RF 73/74/76/78/79/80/81
Viking – None
Winkleman (Became Nomad –Palliser) – KHF/1 (WDF4), KHF/2 (WDF5/6)
Zink – Z-10
Zeus – FF81
Any otherwise eligible FF70 Formula Ford not on the MR Eligibility List may be considered for eligibility upon application to the MR President or his designee, by the car owner.
FF70 Formula Fords will comply with the rules specified in the Monoposto Racing Rules and Regulations for Pre-1973 Historic Formula Fords (hereafter referred to as Pre-1973 Rules) and general rules specified in the Monoposto Racing Rules and Regulations with the following exceptions and clarifications:
II. ENGINE
a] General
The engine shall be the standard Ford 1600 pushrod crossflow, as specified in the Pre-1973 Rules. Specifically, aluminum heads and solid state ignition systems are not permitted.
III. TRANSMISSION
Per Pre-1973 rules.
IV. FINAL DRIVE
Per Pre-1973 rules.
V. CLUTCH
Per Pre-1973 rules.
VI. CHASSIS
Monocoque chassis construction is not permitted.
VII. SUSPENSION AND RUNNING GEAR
Shock absorbers are free with the exception that external reservoirs are not allowed. CV joints are permitted. At a minimum, one end of the car shall have outboard suspension.
VIII. BODY
The body shall conform to the original design. Alterations made to improve safety and competitiveness are permitted.
IX. BRAKES
Cockpit brake bias adjusters are permitted.
X. WHEELS
Wheels shall be 13’ with a maximum width of 5.5". Wheel covers, wheel faces or any device to fair in wheels is prohibited. Wheels must be metal (steel, aluminum, magnesium…).
XI. TIRES
Tires shall be slicks which fit the 13” by 5.5” wheels. Tire manufacturer and type are free. Rain tires are permitted.
Xll. MINIMUM WEIGHT
The minimum weight is: 950 lbs. [including coolant, fuel and lubricants, but no driver].
XIII. FUEL TANKS
Per Pre-1973 Rules.
XIV. ORIGINAL SPECIFICATIONS
All FF70 Formula Fords must compete in the specification as manufactured and raced. Updates and modifications which were made during the life of the car to improve it’s competitiveness and safety are permitted. However, the racer, if challenged, must be able to demonstrate that these changes were in compliance with the SCCA GCR’s in effect during it’s racing history.
XV. RACING WITH FORMULA CLASSIC CARS
FF70 cars may not race in any Formula Classic race.
XVI. PRESENTATION
FF70 cars shall be presented with a clean and finished appearance in keeping with the spirit of vintage racing. Cars with a rough appearance or otherwise deemed inappropriately presented may be excluded by Monoposto/race officials.
Dan Schmutte
Vice President
Monoposto Racing
creekboy80@aol.com
