Results 1 to 6 of 6
    Vancouver at heart but Adelaide is where you'll find me
    Liked: 16
    Default Steering Rack Boot
    Anyoneknow where to find a specific steering rack boot
    1 1/4 at the big end and 1/2 at the small end over 4 1/2 long
    tricky part is i need a small OD 2" max
    tried all the local suppliers but everything is so darn big in OD
    mukwonago, wisconsin
    Liked: 96
    Default EBAY
    When I needed a boot for my Tiga, I spent some time searching EBAY and ended up finding something that worked great. I bought 2 extra so I will never need them
    john f
    New Jersey
    I bought a boot from McMaster Carr, cut it to length, and fasten the ends with Ty-wraps.
    So.Cal.
    Dorman Products has a few rack boots that are cut to fit. Possible number is
    614-020 . Most larger real Auto Parts stores should have.
    Tacoma, WA
    Liked: 323
    I suspect any off-road parts shop will have shock boots or steering damper boots that will fit your needs. Probably will be longer than you need, but you can always cut them down.
    second for McMasterCarr......
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Sydney, Australia
    Liked: 146
    I found a universal CV joint boot at my local spare parts shop worked fine. Only a couple of dollars and it came with a range of diameters at both ends. Just cut to fit.
