Results 1 to 39 of 39
    ApexSpeed Photographer Dennis Valet's Avatar
    Long Island
    Liked: 60
    Default DSR at the 2012 Runoffs
    Last year I saw some wild stuff going on in DSR development (Carbon springs or something like that if I remember correctly?)
    Any rumors floating around as to what we might see this year?
    A completely bespoke turbocharged 670cc engine putting out 300+ hp.
    VA
    Isn't there one of those every year that breaks and ends up getting swapped for a gsxr1000 some time during the week?
    The only one's I've seen so far have been destroked motorcycle engines...and yes, they couldn't hold together.
    I am told that the new one is a one-off mini auto engine with in-line gearbox. I guess we'll learn the truth during test week.
    Contributing Member John Merriman's Avatar
    North Haven, CT
    Liked: 61
    Default 300 HP?
    $300 HP? Good lord. What's the power to weight ratio? And if you pop the clutch and floor it, does the car move forward or just sit there carving out two 6" deep holes in the pavement?
    VA
    ORLY? This is relevant to my interests.
    Quote Originally Posted by starkejt View Post
    YARLY. Check out this thread from over on the DSR forum.
    VA
    Quick question. Is it a crime against nature to mate with a race car?
    Default Depends
    In Georgia, the answer is yes, but that can be negated by eating at a Chik fil A.
    VA
    If you start serving chicken fried in peanut oil with waffle fries, I'm going to eat it regardless of your political beliefs. I don't care if your restaurant is called Amalgamated Puppy Stranglers or Holocaust Deniers.
    Contributing Member NPalacioM3's Avatar
    Vienna, VA
    My name is Nick Palacio and I approve of this message.
    See what I did there?
    -Nick
    I'm still thinking on it, but I'm leaning towards "no".
    Long Island
    Liked: 60
    why limit yourself to one exhaust pipe?
    Quote Originally Posted by Dennis Valet View Post
    If he'd paint it black and add a dorsal fin with spines sticking up, it's make a passable Batmobile...
    /not a criticism, btw...I'm big fan of the Millers
    VA
    Just think how hilarious and rapidly-accelerating those babies would be.
    Senior Member KVS84's Avatar
    MA
    Default BMW WF1
    I saw a WF1 today powered by a BMW S1000rr. Looked pretty fast.
    -Keegan
    P1 #84
    Stohr WF1 BMW
    Senior Member KevinFirlein's Avatar
    Liked: 14
    since you own it I guess ya saw it
    Kevin Firlein Autosport,Inc.
    Greenwich NJ
    Quote Originally Posted by KVS84 View Post
    I heard the electronics are extremely difficult to defeat...can you share any info?
    MA
    Default Electronics
    Factory electronics are impossible. Haltech ECU and a knowledgeable tuner and you're good to go!
    -Keegan
    P1 #84
    Stohr WF1 BMW
    Greenwich NJ
    Wow!
    Wet or dry sump?
    What max RPM are you using?
    Coral Springs, florida
    Liked: 84
    I also heard there may be a Kawi DSR out there. Any word on that?
  22. #22
    MA
    Wet sump and 14k rpm's.
    Having an engine that makes 25 pounds hot oil pressure is amazing.
    -Keegan
    P1 #84
    Stohr WF1 BMW
  23. #23
    Somerset, Kentucky
    Liked: 126
    My oil pressure in the new Kawi with BRD dry sump was up at 75 PSI hot from memory. I'll check my data.
  24. #24
    Default Wha?
    You refering to idle OP?
    Yeah amazing what can be done when there is no rule to utilise the stock ECU.
    Look forward to seeing the results @ RO's.
  25. #25
    MA
    Yes that's idle pressure. 55-75 on track.
    Stock ecu is a very stupid rule for FB. The cost argument makes no sense. The Pi system in my car cost double what the Haltech ecu system did.
    -Keegan
    P1 #84
    Stohr WF1 BMW
  26. #26
    Greenwich NJ
    Agree 100%. We need to get some newer engines running in FB.
  27. #27
    Huntsville, AL
    How many track miles on the BMW engine so far?
    If the stock ECU rule keeps engines making a lot more hp out of FB, then it is far from stupid.
  28. #28
    MA
    Has nothing to do with making more horsepower it just makes the engines work period. You can reflash ignition maps with a stock ecu and use a bazzaz to tune your fuel in FB. 2 days so far on the Beamer and couldn't be happier. Running tomorrow also. Stock it makes same HP as built Suzuki with out the oiling problems. Can't beat German engineering.
    -Keegan
    P1 #84
    Stohr WF1 BMW
  29. #29
    MA
    Although I do understand Wren if you mean keeping HP levels at the current spec engine 07-08 Suzuki that makes sense. 190-200 is the new standard for liter bikes. I will keep everyone posted on mileage and durability! So far beyond pleased. Tons of power and
    Great oil PSI.
    -Keegan
    P1 #84
    Stohr WF1 BMW
  30. #30
    Greenwich NJ
    Wren, I think you are merging two different topics.
    1) Limiting FB power might or might not need to be addressed. IIR or RPM limits sound like intelligent ways to control power escalation.
    2) FB needs a long term viable supply of engines. K7 and K8 GSXR's are going to become scarce at some point; they are already significantly more expensive than 2 years ago. All new liter bike engines are going to have sophisticated electronics that can be impossible to work around the stock ECU; it seems disingenuous to not allow this supply of current engines to flow into FB.
    As you know, I am a Stohr fan. I would like to order a new car but spec'ing out a 2013 car with a 2007 engine seems ridiculous.
  31. #31
    Liked: 84
    Limiting HP and keeping competition at a somewhat even level in FB would probably best for the class in the long run. Think about it, who would want to race in a car that is not competitive? and right now that means the entire FB community. People would drop out instead of spending the money to fit and test a new engine. FB numbers would drop dramatically. Besides the fact that at 200hp they would probably have quicker lap times than Atlantics (not sure what kind of problems that would cause). On the othe hand it is going to get harder to find the older gsxr engines and the new gen engines are all at the higher HP levels now. Limiting the the RPM's (if easily doable) seems like the way to go to accomplish a level playing field and bring newer engines into the game. How would RPM limiting work and is it expensive?
  32. #32
    Marquette, Mi.
    Liked: 43
    The last two posts should be moved. I think we have gotten a bit off track with this thread.
    Back to our DSR/ Runoffs topic please. DSR is our testing grounds for technology for FB but we shouldn't steal their thunder with the exciting stuff that we all would like to see at the runoffs.
  33. #33
    member Brett Lane's Avatar
    Ft. Lauderdale
    Ok,
    Didn't George Dean get the Kawasaki ZX-10R to work with the stock ECU?
    And speaking of neat DSR stuff, Didn't someone mention sleeving down a GSXR 750 for turbocharging? Could that be relatively, remotely, kinda reliabe?
  34. #34
    St. Louis, MO
    I believe Tom Bootz has run a turbo sleeved GSXR 750 and actually finished with it at the 2010 runoffs. Didn't appear to be a world beater. I believe they may have had exhaust valve issues. I also wonder if the bike transmission would withstand the alleged potential of 300+ HP. I have publically stated many times that a real turbo DSR will have to have an automotive transaxle and live with the 1000# minimum weight that would entail.
    For those of you with long memories, the old 1500cc turbo F1 motors were capable of close to 1500 HP in qualifying. That was using fuel that guaranteed that you didn't want to ever have kids. Current SCCA fuel rules would probably limit a 670cc turbo to around 350HP.
    Marty
  35. #35
    Greenwich NJ
    Great oil PSI.
    Keegan,
    May I ask how much the Haltech ECU costs and how much effort and dyno time is required get it set up for your car?
    Ivin
  36. #36
    Markham, Ontario
    Deleted
    Marty
    Tom Owen
  37. #37
    Senior Member turnbaugh's Avatar
    Austin, Texas
    Default Ducati?
    I think this may fit in this thread.
    Why isn't anyone using a Ducati engine in a SR?
    Dean
    Wolf GB08
    Austin
    www.motorsports-sw.com
  38. #38
    Liked: 84
    Quote Originally Posted by turnbaugh View Post
    Because they suck.
  39. #39
    H-Town, Texas
    Audi just bought them; makes more sense for a sports racer.
    Ken
    Ken
