I have an old formula Vee, (63 Sardini) Still mostly original except a 1600 putting out about 60 hp, Everything else still old Vee, drum brakes 5 inch wide tires, stock steering box and way over weight. I have been racing SCCA Solo in FM, The problem is the Red Devils and similar cars, they have more Hp less weight and wider tires, disk brakes and rack and pinion steering. I can not keep up them. Is there any other Solo Class and old Vee can run in with a better index (PAX)?
