Results 1 to 6 of 6
    Contributing Member TeamFRD's Avatar
    FL, USA
    Liked: 15
    Default Dry Sump Oil Tank - 6 quart - aluminum
    Dry Sump Oil Tank - 6 quart, 6 inch diameter, 15 inches high (total), 12.375 high (cylinder) aluminum.
    Top screw cap, one inlet, two vents, two outlets at bottom, drain pulg.
    $80 [FOB Florida 32003]
    Four pics here-- http://www.flickr.com/photos/yspect8/5801532737/
    Top cap: OD of thread 1.74" (with aluminum cap)
    Top swirl inlet: ID .375 / OD of thread .746"
    Top vents: ID .540 / OD .624
    Bottom male: ID .605 / OD 1.055 of thread
    Bottom female: ID thread base .720 (.785 with thread)
    Drain plug: .565 hex / OD of thread 1.44
    From the top edge of fill cap, there is a down tube extending down 4"
    One vent tube, with the VENT stamp, goes through the down tube. The other vent tube only goes through the outer wall.
    There is a shelf or tray with five .5" holes near the outside wall and 1.5" hole in the center at 8.25" from the top of the cylinder.
    The male outlet fitting has a tube to the center of the cylinder. The female outlet only goes through the outer wall.
    Last edited by TeamFRD; 05.06.12 at 6:19 PM. Reason: add measurements - price chg to 80
    Bethel CT
    What size are the fittings on there ? Can you get me a price on shipping it to CT,06801 ?
    San Jose, Ca
    Liked: 90
    Any chance that tank is from a cheetah DSR?
    FL, USA
    Liked: 15
    Default Fitting sizes
    Quote Originally Posted by monte442 View Post
    Additional info added to original post.
    * Estimating 11 pounds, large package: about $15.00
    * Not sure what it was used for before I bought it.
    FL, USA
    Liked: 15
    bump - price change to $80. You pay shipping.
    New Oxford, Pa
    Default DS tank
    I'll take it.
    Thanks, Doug Shipping to 17350
