Not looking for medical advice.... just a question that I don't know the answer to. On the SCCA medical form is says that if a persons blood pressure is more than 160/60 they must be referred to the SCCA Medical board. I can see that would pretty much rule you out.
My question is this. If you have your blood pressure under control with doctor prescribed medication and it is less than 160/90, are you ok? In other words... does taking medication to reduce your blood pressure disqualify you?
Further down, it has a yes/no check box that asks if you have a history of High blood pressure. If you answer yes there, does that knock you out even if you test less than 160/90 during the exam?
I am assuming that since a lot of the FV drivers are "mature" a lot of them are on blood pressure medicine and that is OK with the SCCA as long as it is lower than 160/90. Am I wrong?
