    Walworth, NY
    For Sale 2009 F-Mod National Champion Red Devil- $5,500 w/ Spares
    SOLD --- SOLD --- SOLD
    Looking to sell my 1984 Dare Devil F500. This car was driven to the F-Mod National championship in 2009. This car was developed by Jim Murphy and is now available. I am going to B-Mod and would like to sell the car before the 2012 season starts.
    This car is a blast to drive and is capable of trophying at Nationals in 2012. You won't go faster for less.
    Car is located in Walworth, New York.
    I'm asking $5,500 for the car and extensive spares package. This is a great deal for someone looking to get started in F-Mod. The car is set up for a tall driver (I'm 6'4")
    1984 Red Devil w/KBS Mk.7 rear clip
    Rotax 493 – good compression, MPEM, electric starter and Weinandt pipe
    Muffler with mount – good for 92+dB
    Rocker arm front & rear suspension – optimized
    Inline electric water pump w/switch – cools motor down between runs
    Two new custom aluminum radiators w/fans on same switch as above
    Copper tubing used in parallel cooling system
    Electric water temperature gauge
    Smallest steering wheel on steel/steel take off hub
    Quickest steering ratio on aluminum steering arms
    Optima on board motorcycle battery w/quick disconnect to Optima booster battery
    Chain drive moved to left side for lightest arrangement (new 12t/55t sprockets)
    Chrome moly gun bored rear axle assembly w/4 piston caliper
    Biggest K&N air filters that would fit
    Digatron 4 display data logger – RPM/MPH/L-EGT/R-EGT
    4 aluminum trailing arms with aluminum panhard rod
    2 gallon aluminum gas tank w/foam filler under the seat
    Electric fuel pump w/switch and vacuum fuel pump (primes carbs before cold starting)
    RR style master kill switch
    New Polaris primary clutch, optimized setup & new clutch belt
    Main roll hoop raised 4”
    Partial Spares List
    12 (6 front & 6 rear) R25 19.5x7.5 tires mounted/balanced on spun aluminum wheels
    12 (6 front & 6 rear) R25 18.0x7.5 tires mounted/balanced on Kodiak aluminum wheels
    4 (2 front & 2 rear) Rain 19.5x6.5 tires mounted/balanced on Kodiak aluminum wheels
    1 spare (less carbs, starter, plug wires w/coil & MPEM) good condition Rotax 493 motor
    1 complete Rotax 493 w/ poor compression on one cylinder (less carbs, starter, plug wires w/coil & MPEM)
    Complete set for rebuilding a 493 – gaskets, seals, etc
    Quick lift rear jack
    Custom large pit cart that hitches to back of race car
    Spare MPE
    Set of about 20 Mikuni jets in board & carb tool kit
    Polaris P85 used lightened primary clutch w/big bushing cover & starter ring
    2 used starters
    Spare calipers
    Boxes of clutch tuning components and clutch tools
    Mikuni tuning manual, clutch tuning manual
    I also have a 7' x 14' enclosed trailer that I will sell with the car for an additional $3,200. Trailer was built in April of 2011.
    Depending on your location, I may be willing to deliver.
    Steve Hayward
    585-298-3585
    stevekh@rochester.rr.com
    Atlanta, Georgia
    This is an absolute steal!! The spares are worth close to $5K just by themselves.
    If you want to be in the hunt at the Lincoln Nationals this is the car to have.
    Atlanta, Georgia
    Steve forgot to mention that he did a complete frame-up rebuild and paint job.
    Walworth, NY
    Default SOLD
    Car has been sold.
