Ok I have 4 decent solid beams in my shed that I picked up at a junk yard. I also have a ball joint beam that I have tore apart. When I rebuild these for FV use what should I look for as far as the internals? I have toothed adjusters to weld on , I don't see many toothed adjusters out there is there a reason everyone uses the screw type? How can I tell if the spindles and ends are ok?
G.
