Does anyone have closeup photos of the BRD setup?
Also what are your feelings on the BRD unit?
G.
G.
G. Brian Metcalf
72 AutoD MK4
1991 Mysterian M2
2014 ALR73 FV/FST
Not the greatest picture, but you can get a handle of how it works. Next time I am at the shop, I can get a few better detail pictures for you if you wish.
As far as the BRD as a whole goes, it's a really nice, tight, friendly package. I find that the rear suspension is very predictable, and easily tuneable. We have been running two BRDs for the past couple years, and have had good success with them. With the right engine and the right driver, they are very capable to hang with other top national level cars. Guy Bellingham has run many national races, and ran the run offs last year, doing quite well.
The cars themselves are very user friendly. They are very wide open in the back with the bodywork off, so very easy to work on. Engine can come out and back in within 30minutes if you know what you're doing. Being a unique upright seating position, I find that they taylor to karting drivers or drivers coming from tin-tops. The purpose of the seating position was designed to move the CG as far forward as possible, and sacrifice a bit on the z-direction CG.
Shane Viccary
#27 Citation-Zink Z-16
by the way, both of them are for sale in the classified area. We are looking to sell one or two of the three cars that are listed (2 BRDs, one Stiletto) because we want to focus on a small, strong operation for next year...not because they lack in potential! Just too many cars right now...
Shane Viccary
Where can you purchase these?
G. Brian Metcalf
72 AutoD MK4
1991 Mysterian M2
2014 ALR73 FV/FST
To me the BRD set up looks like it wants to tear the tubes out of the gearbox with the push rods so horizontal. Anyone ever have any wearing issues with axles or tubes? It looks like a nice compact design.
Mark Filip
http://vallismotorsport.com/
The best way to reach Bill is by the phone number on the website. He has parts on the shelf. If there is a negative to the system, its that you cannot have an economy version due to the shock absorber requirements. It needs a good shock. The standard version above uses a 10" shock. I prefer the geometry with an 11" shock and normally run that configuration (lower pic).
I have one system on the shelf but I have been too busy to get a shock together for it. I should have it for sale in the new year.
No real wear issues with the setup, but reinforcing/backup plates for the axle tube retainer/cover are recommended.
Virtually no one in Canada uses the reinforcement plates. The BRD rear suspension works just fine and has no more or less issues than any other car. Like any FV, when you crash or have extreme curb abuse, you can stretch the axle boot flanges. Under normal use there are no issues.
This suspension has become common because it is truly "bolt-on" and can work with forward or rearward facing trailing arms. It will fit on most any car with only clutch system mods and clears most exhaust systems. It is compact and light.
I run a BRD with FRCCA. If you still require close up shots of the rear suspension email me and take some and send to you.
What spring rates are typically run with this setup?
MK
I am developing my own version of the BRD suspension for use on any FV or FST. I am figuring between 250-300lb spring. All of my parts are laser cut and I am using roller bearings to reduce friction. Testing will begin soon.
Scott
What is the typical distance between the top of the transmission (under the BRD suspension saddle) and the top of the spring? Trying to see how much clearance is required with the exhaust.
Spoke with Bill this morning and this is the one question I forgot to ask...
Jean-Sebastien Stoezel
Western Canada Motorsport Association (WCMA)
FV #0
my BRD ran a 300lb spring i would probably run something a little softer though if i had options at the time
Andrew McMurray
London ON
aandrewwmc at hotmail dot com
