Page 1 of 2 12 LastLast
Results 1 to 40 of 52
    Fort Worth, Texas
    Default New Intrution Panels on Outside of Cockpit
    Did anyone see the latest Fastrack that came out yesterday. It looks like they are requiring panels on the outside of the roll cage structure to prevent intrusion into the cockpit for all formula cars. My Stohr right now doesn't comply as far as I can tell so I'll be needing to do some mods.
    Any comments?
    James
    Maryland, US
    Liked: 77
    Anti-intrusion panels are already required in FB - see 9.1.1.H.2.C.
    What the new rule does is to permit a third option for intrusion panel construction. This also applies to FF, FC, FM, FV and FST.
    Dave
    Fort Worth, Texas
    Default When did 9.1.1.H.2.C go into affect?
    When did 9.1.1.H.2.C go into affect? I raced my car in 2009 and did not have them. Was it after that? Thanks much.
    James
    VA
    Sure you don't have kevlar in the body side panels?
    Huntsville, AL
    Quote Originally Posted by James Michael View Post
    James
    Long before the FB rules. I would guess that you have Kevlar in your body side panels.
    Fort Worth, Texas
    Default Anti-Intrusion Panels
    My bodywork is fiberglass - almost 100% positive BUT I'll check with Stohr on that! Thanks for the info.
    James
    VA
    This rule existed when your car was built. Respectfully, I bet you have kevlar in there.
    9.1.1.H.2.C
    The area between the upper and lower mainframe tubes from the
    front roll hoop bulkhead to the rear roll hoop bulkhead shall incorporate
    one of the following:
    1. Panel(s), minimum of either .060 inch heat-treated aluminum
    (6061-T6 or equivalent) or eighteen (18) gauge steel, attached
    outside of the chassis tubes.
    2. Reinforced body - at a minimum, consisting of a double layer,
    five (5) oz., bi-directional, laminated Kevlar material incorporated
    into the body which shall be securely fastened to the
    frame.
    For either method, fastener centers shall not be closer than 150mm
    (no stress-bearing panels). The material used for the chassis braces
    in this area shall be at least equivalent to the roll hoop brace material.
    Fort Worth, Texas
    I may be mistaken then. I'll check with Stohr on the Kevlar. Thanks for the info.
    James
    Senior Member VehDyn's Avatar
    Texas
    How does this new ruling or clarification or whatever effect the Radon?
    Ken
    Contributing Member farrout's Avatar
    Sanibel, FL
    Quote Originally Posted by Dave Gomberg View Post
    Dave
    As I read 9.1.1.D.7.b (FF and FC), it basically came into effect on January 1, 2010 and "All new Formula Ford cars are to be built to these specifications covered in D.6 and D.7". The new wording essentially adds section b.3.
    For FFs who were homolugated prior to January 2010, the intrusion panel requirement does not apply. I could not find any back dating language.
    Dave - Is this a correct reading of the GCR?
    Thanx
    Craig Farr
    2006 Stohr WF1 P2
    FARROUT Racing
    Maryland, US
    Liked: 77
    The intrusion panel requirements have been in place for FF and FC since 1986. The same requirements have been in place for FV "forever" and in FB since its inception. The only thing that is changing now is that there is another method to satisfy the requirement.
    Dave
    Default Meanwhile
    the panels that contain Kevlar are attached to the chassis w/ 3mm screws; yeah that oughta 'bout do it!
    Huntsville, AL
    I wouldn't worry too much. The screws just keep it located. The strength is in the tubes backing it up. The panels are there for intrusion resistance and that is all about something pressing against the panels, which shouldn't really load the fasteners, except some in shear maybe.
    When was the last time you saw a car have the body sides torn off?
    Default True
    dat.
    Liked: 1879
    What is funny is this:
    [i]Modify 9.3.36 as follows:
    “NON-METALLIC WHEEL/CHASSIS CONSTRUCTION
    Non-metallic wheel construction is prohibited. Non-metallic chassis construction is prohibited, except in ASR, CSR, DSR, S2, FS and FA. New chassis of non-metallic composite construction shall be proven to meet FIA specifications for non-metallic composite chassis prior to being submitted to the SCCA for homologation. Contact the SCCA national office for a list of the relevant FIA specifications/SCCA requirements.”
    Sounds innocuous enough, until you read this:
    Technical Glossary
    Metallic – A material having iridescent or specular (mirror-like) reflective
    qualities (e.g. aluminum foil)
    Looks like you guys are gonna have to spend a LOT of time polishing your wheels and tube frames!
    VA
    Even if we throw aside the fact that it defines an adjective (metallic) in terms of a noun (material), that is perhaps the worst definition I have seen. Almost as bad as:
    Circular - A shape having the qualities of a circle (e.g. round)
    Contributing Member Reddog's Avatar
    California/Michigan
    frame.
    works for me ...
    California/Michigan
    Quote Originally Posted by starkejt View Post
    [FONT=Calibri]How about a sphincter?[/FONT]
    VA
    No, thanks. Just had one. Appreciate the offer, though.
    California/Michigan
    [FONT=Times New Roman]Just one? ... and there was no offer.[/FONT]
    [FONT=Times New Roman]Or are two sphincters an option in the latest Mister Potato Head [150 mm O.C.] ?? [/FONT][FONT=Times New Roman]JK don't mean to butt spuds ...[/FONT]
    VA
    One is my limit. I'm driving.
  22. #22
    Liked: 1879
    Almost as bad as:
    Your 'circular' definition reminds me of my search to find out exactly what the heck a "neoconservative" was supposed to be - all I could ever find was "One who practices Neo-conservatism". I never could find a definition for neoconservatism - other than that it is what is practiced by neoconservatives.
    Ya just gotta love trying to interpret and follow the GCR!
  23. #23
    Liked: 1879
    Quote Originally Posted by Reddog View Post
    Isn't that what is practiced by sphincts?
  24. #24
    VA
    Which escapes you more? Defining "neoconservative" or solving the age-old Riddle of the Sphincter?
  25. #25
    California/Michigan
    [FONT=Times New Roman]plural?? isn’t that sphinctii ? [/FONT][FONT=Times New Roman][/FONT]
  26. #26
    Santa Cruz, CA
    Really? You live in Indiana and you don't know the definition of neoconservative?
    Me, I prefer neofuturists
    'Stay Hungry'
    JK 1964-1996 #25
  27. #27
    Liked: 1879
    Default Someone claimed that they were an endangered species.....
    Actually, I always thought that neoconservatives were exsphinct.
  28. #28
    California/Michigan
    [FONT=Times New Roman]I’m a paleo … an am glad “neo’s” saw the light … ... [/FONT]
    [FONT=Times New Roman]Josh you make me laugh ... [/FONT]
  29. #29
    VA
    Rimshot
  30. #30
    VA
  31. #31
    California/Michigan
    Quote Originally Posted by TimW View Post
    Santa Cruz? ... ex Boulder Creek dude here ... [long divorce story no extra charge]
    neofuturists ... please the mid west just won't understand ...
  32. #32
    Liked: 1879
    Next time I want to see a sphinct, I'll take a plane to Egypt.
  33. #33
    Santa Cruz, CA
    The neofuturists are a midwest thing. A theater troupe in Chicago based on the Italian turn of the last century Futurist movement with defining principles of speed and chance. Their long running play is 30 plays in 60 minutes called Too Much Light Makes the Baby Go Blind. Up to 18 plays are rewritten each week, the number decided by three rolls of a 6 sided die. The cost of admission is dependent your role of a six sided die. Theater space is above a funeral parlor in Andersonville. Apparently the rent is cheap. This American Life did a homage show to them a few years back.
    Boy, did this get way off topic.
    Santa Cruz all good. So is the leather appointed wi-fi enabled motor coach my employer is driving me home with right now!
    Tim
    'Stay Hungry'
    JK 1964-1996 #25
  34. #34
    California/Michigan
    [FONT=Times New Roman]Next time I want to see a sphinct, I'll take a plane to Egypt.
    [/FONT]
    [FONT=Times New Roman]Hope you wear a burka … or as we used to call them BMO’s [Black Moving Objects] [/FONT]
  35. #35
    California/Michigan
    Tim
    I stand corrected ... I do love the mid-west but SC is my real home...
  36. #36
    VA
    Sounds like a perfect application for the specialized six sided die I developed. One side has a zero on it, and the other 5 sides each have a fist on them.
    If you ever have any misgivings about the usage of tazers and tear gas, look no further than neofuturists.
  37. #37
    California/Michigan
    [FONT=Times New Roman]So candle lighting thespians should be tazered and tear gassed [banned by the Geneva Convention] … you cannot be serious … ?[/FONT]
  38. #38
    VA
    Try though I might, no, I cannot be serious.
  39. #39
    California/Michigan
    Whew ... glad I heard that ... although some of those OWS types.... Well ??? I dunno know ...lets just say they will grow up ...
  40. #40
    California/Michigan
    So … another ApexSpeed thread closes for the night … went from “ see 9.1.1.H.2.C” . too “candle lighting thespians” … all is right with the world ... ... fair winds all
