Made some updates to the ol gal:
Heat shield for fuel cell before and after
Oil line made from stock Suzuki oil cooler line and welded on -10
This projects the -10 nipple further forward then the Peter D M/S's red anodized part, so now 90 degree fitting can attach right on and run the line straight across towards the right sidepod/cooler, staying as far away from the header as possible.
New ceramic coating, should see greatly reduced "underhood" temperatures.
New engine mount shims replace washers that were extremely problematic to install.
The top mount rotates rearward and is paralell to the aluminum mount, bottom just hangs. I had some metal stock that was the correct thickness: 2 tabs for the bottom, three for the top.
