    Contributing Member bmumm's Avatar
    Minneapolis
    Default Engine Dress Kit and Mobile Engine Stand
    Sold: FE engine dress kit and mobile stand. I put this kit together when we ran L3 in IMSA Lites. When you have to change an engine at the track, having the engine already dressed saves a ton of time and hassle. It's also a slick way to store the spares. Included in this kit are:
    1) Starter (SCCA PN: WM904008, $292.24) with mounting bolts
    2) Front motor block (SCCA PN: WM301007, $178.38)
    3) Front motor plate with bolts (SCCA PN: WM301008, $107.31)
    4) Complete clutch and flywheel (SCCA PN: WM701000A, $857.08) with bolts
    5) Ring gear WM1101053, $170.44)
    6) Motor top studs (SCCA PN: WM1010804, $5.83 ea.)
    7) Ignition coil (SCCA PN: WM992016, $161.18) and wires (SCCA PN: WM301052, $47.51)
    8) Throttle cable rod end (SCCA PN: WM591931, $7.78)
    9) Rear water manifold (SCCA PN: WM401012, $299.83 with temp sensor (SCCA PN: WM904024, $26.67) and banjo bolt and crush washers
    10) Oil filter adapter (SCCA PN: WM301050, $51.92) with -3 oil pressure sensor tap and bolts
    11) Front water inlet flange (SCCA PN: WM401002, $155.23) with bolts
    12) Alternator with pulley (SCCA PN: WM1194009A, $454.80 )with all mounting brackets (SCCA PN’s: WM904012, $34.45 and WM904013, $46.67) and belt (SCCA PN: WM904022, $15.16)
    13) Aeroquip “Startlite” oil lines
    14) Custom low profile engine stand with 4 casters (2 locking)
    15) Steel exhaust port cover
    16) Steel intake port cover
    17) Front and rear lift hooks
    This is over $3,000 worth of stuff (the prices shown above are SCCA 2009 prices). It's all 100% functional, used parts, but totally race-ready -- no junk. The pictures show a motor with the parts installed.
    $1,500 for all. Pick up in Minneapolis, MN or delivery possible to Pro Formula Mazda, IMSA Prototype Lites, or USF2000 races.
    You can contact me at bmumm@mummbrothers.com or on my phone (612) 964-5830. If I'm unable to answer your call, please leave a message and I'll get back to you as soon as I can.
    Thanks for looking.
    Barry
