Just thought I'd make you all aware of what we found. Sunday during qualifying the car lost quite a bit of power. We brought it in and looked it over but did not find much except a very lean exhaust pipe and the car was very low on fuel. We checked over a few things, including fuel filter, and decided the low fuel must have starved the injection system and thus the lean pipe. So we start the race and backward I go! Each lap less and less power until the end of the race when the car was hardly running. SO as it turns out...today we found the fuel injectors totally clogged with black muck. I have had this happen once before and the culprit was bad fuel from the race track. Perhaps we got the bottom of the tank? Either way my point is I suggest you all check out your carbs/injectors, etc. prior to the next event.
Jim Goughary
