Ok so long story short, I put a brand new High Strength Ring Gear on my Crossle w/ Kent power, as the old one was all chewed up and the car would not start. So had a machine shop put the new ring gear on the flywheel, and I put the entire back half of the car together including a fairly new Tilton Super Starter w/ a 9 tooth starter gear.
About 20-25 starts later, the ring gear is shredded again and the car will no longer start. So I take everything apart again and see that in fact the teeth on the ring gear are all shaved down and the starter will catch a few teeth then skip/miss the ring gear.
So, considering a brand new High Strength ring gear got trashed so quickly I'm going to say the starter gear is incorrect. Does anyone know what tooth count starter gear I need for this ring gear?
Ring gear: 10.00" ID, 110 tooth, high strength (Pegasus # 163-07)
Starter: Tilton Super Starter, 9 tooth starter gear
Next question, the standard ring gear is $100 cheaper than the high strength one, should I bother getting the high strength one again? What is everyone else running? I'd like to save the $100 if possible but I won't cheap out if I have to have the high strength one.
Anyone have a new ring gear laying around that I could buy?
Thank you in advance, this is quite frustrating.
