Results 1 to 13 of 13
    Senior Member JJLudemann's Avatar
    Thailand
    Liked: 36
    Default New F1000 First Test!
    After five long years of work, my car finally made it to the track!
    On Tuesday, August 11 we did a shared-track day at Bira International Circuit in Pattaya, Thailand. The trailer's not finished, nor do I have a tow vehicle yet, so we had a slide truck pick the car up and deliver it to the track. Bira's only five minutes from my house, so this was easy.
    So here we are at the track with a car designed from a clean sheet of paper, a prototype that's never turned a wheel, a driver who's ever driven only one lap of this course in a Honda Jazz/Fit several year ago, who's never driven a sequential transmission, hasn't been in a race car in 14 years, never driven with race tires, and tires, in fact, that were bought used several years ago. Also, springs and shocks that turned out to be way too stiff, and no front wing, rear wing, sidepods, or diffuser. Yeah! Let's go!
    Surprisingly enough, the test went great! Through various friends I had four mechanics helping me, three of whom were experienced race car mechanics. Before going out the mechanics went over the car carefully and found a small gas leak at the fuel tank and a slight oil leak at the oil pressure sensor, but those were soon fixed. I did one slow lap, starting to bed in the brakes, then came in for a check. Then I did another 8 laps to finish bedding-in the brakes and brought the car in for a complete check. At that point we had to adjust the drive chain tension.
    After I rested I went out again for several more laps trying to bring the speed up, doing a best lap around 1:28, still very slow for Bira. I brought the car in when my neck couldn't take it anymore, after only about six laps. The issue was not so much cornering force as it was the wind pushing my helmet backwards; I just couldn't hold my head up against it. We found a few issues like the torque spec on the left front wheel bearing was not high enough, leaving the axle free to wobble a bit in the bearing. Also, the left rear lug nut backed off, and the throttle cable came loose at the engine bracket. We increased the lug nut torque spec and reversed all the nuts so the flat side contacted the wheel as we decided the radius on the wheel was too small to properly contact the conical face of the nuts.
    For the third run I brought the speed up more, with a best lap of about 1:21, but the car was undrivable at high speed. I believe it was actually bouncing in the air on the straight, as I could hear engine speed variations even when I wasn't touching the clutch or gear lever. I kind of expected something like this as the springs are way too stiff. Anyway, the stiff springs bent the right rear suspension pushrod adjuster, and we were done for the day.
    So overall, the suspension geometry feels perfect. The engine, transmission, electrical system, frame, steering, cooling and almost everything else worked flawlessly.
    Wow, it fast! It's the most amazing thing I've ever driven. It makes my old twin-plug 3.5 liter Porsche 930 feel like a tractor. But it demands precision and skill-- I felt like an elephant learning to tap dance. As I'm sure you will see from the video, my shifting was all wrong. All the action in the clutch is in the first half inch, whereas the throttle pedal moves like four inches so coordinating the two was difficult. In addition, I was still driving it like a normal transmission, using the clutch on upshifts, as we decided to learn proper sequential shifting in a later test. I can see that with some suspension tuning, aerodynamics, tires, and a software upgrade for the nut that holds the steering wheel, the car will be seriously fast.
    Thanks to everyone on Apexspeed who has provided advice, technical knowledge, and emotional support over the years. I couldn't have done it without you!
    So now, here's the video: http://www.youtube.com/watch?v=tqvzVhj-_Qs
    -Jim
    Contributing Member PaulT's Avatar
    St. Charles, IL
    Default Awesome
    Congratulations! This is great.
    Paul
    Liked: 291
    Default again congratulations....YOU did it!
    More pit girl please...................................
    Liked: 1868
    Congratulations! It is always fun - and a giant relief - when you get a new build out and running!
    Alpine California
    Liked: 273
    Default Congrats!
    Congrats on your first test day.
    For those of us that have built cars from scratch the feeling of finally driving your creation is unreal to say the least.
    Holy Cow.....2,500 Baht ($70 US) you can rent the Bira track for an entire day. If I lived 5min from a track that was that cheap I'd never get anything done.
    Gary Hickman
    Edge Engineering Inc
    FB #76
    Alpine California
    Liked: 273
    I noticed in your post that you mentioned in your last session you had a hard time keeping your head from getting pushed back. This can be fairly painful and a serious distraction.
    Couple of years ago JRO shared a karting tip with me. He wears a tether that attaches to front of the helmet at the chin opening and is looped thru the lap belt. Apparently this is a trick the super kart guys do. Figured if it was good enough for him I'd give it a try.
    I've been wearing this chin strap tether for a few years now, it works.
    Gary Hickman
    FB #76
    New market, AL
    Gary's right. I wore one in the top fuel car. They work. Congrats on the car build. Most people wont stick with it that long. Very well done.
    Jerry
    Liked: 1397
    Years ago I had a similar problem with the air hitting my helmet to the point that I could not keep my head upright at high speeds.
    On that car the fix was a horizontal piece of Lexan along the top of the cowl that extended forward about 1 inch. On other cars I had a vertical piece of Lexan about 6 inches wide and up about 1 to 2 inches. The vertical deflector solved the problem of air beating my helmet around and was very useful in the rain to help keep my visor clean.
    delaware
    Default Low downforce.........
    Me thinks it may be your low downforce setup LOL.
    Yessssssss..............
    Great Job.........
    Steve W.
    Liked: 432
    Congratulations. Great video . The GoPro on your helmet wouldn't have helped with the helmet getting pushed back either.
    Graham
    Liked: 291
    it apparently did not help Schumacher either
    Ontario, Canada
    Good Stuff.....Congratulations
    BC Canada
    Default Congatulations.....
    Congratulations JJ, I know how you feel after so many years.
    You beat me to it.
    Desmond
