Results 1 to 9 of 9
    Member Offfield's Avatar
    san diego
    For Sale race car hauler 1996 diesel step van
    For sale race car hauler 1996 Stepvan, utilimaster all aluminum body, Freightliner chassis, Cummins 3.9 turbo diesel, 5 speed road ranger transmission, from behind drivers seat to roll up rear door is 18 feet. Wall to wall is 94 inches. storage beside drivers seat in floor. Has drop down bed over driver can use while driveing. Butcher block counter top with sink and 4 cuft fridge, also a inverter microwave that will do 12" pizza. Running water. 20 gal fresh water 25 gallons gray water tank. There is 6kv diesel generator on a roller bearing pull out slide in the left rear. Electrical outlets are on the right rear and three in the front inside with gci's, 150,500 miles,have all service records since new, and all updates and services are current. Tires are 225-19.5 yokohamas 90% with new spare. any question please call terry 1-619-276-2623 $12900
    Hauled rally car or formula Jr gets 16-20 mpg. max car size would be 14.5 feet. there is tire storage in vertical stack for 4 or 8 mounted tires depending on how wide they are, and a tool box under the passenger seat.
    So.Cal.
    Liked: 29
    Default Terry did a grat job on this unit...and
    he is great with motors...and car haulers!
    So T..... are you retiring?
    JB
    san diego
    Default stepvan
    Hi Jerry: Yes I am retiring from rallying. we did ok last year 5 in southwest rally series and 1 in crs rally series. had a lot of problems with axle breakage but a canadian firm made some custom axles that fixed that. didn't finish prescott because of dirt on the maf not going to use aftermarket oiled airfilters again.
    When are you going to send me some pictures of your lola.
    Terry
    Vancouver BC
    Liked: 49
    This is my dream tow rig, pretty much Can't reasonably afford it or justify the expense just yet, but one day, one day..
    Senior Member turnbaugh's Avatar
    Austin, Texas
    Liked: 9
    How hard would it be to get a sports racer in and out of it? How long of a car would it hold?
    Dean
    Wolf GB08
    Austin
    www.motorsports-sw.com
    Markham, Ontario
    Default seventy Foot Ramps
    would probably be enough!!
    Dean, the best way to laod a SR in and out of the truck would be to mount a "cherry picker" engine hoist on one of the two rear corners of the van. Then lift the car into the truck. A decent engine hoist is only a couple of hundred bucks and works great for this kind of work.
    Not only can it move the car in and out, but will be handy for engine changes and lifting the car to place on a roll-around.
    That's how I would do it.
    Quote Originally Posted by turnbaugh View Post
    Tom Owen
    ASRF1000
    Guest
    What is the maximum length of a car that the van can hold? What is the overall length of the van and the length from the back to the top of the windshield?
    So.Cal.
    Liked: 29
    Default Terry doesn't frequent Apex so........
    You might call him in So Calif or e-mail him for a quick answer. I do know that the floor is pretty low...like trailer low.
    san diego
    Hi: The inside will take a 14.5 foot long car However the floor is not flat there are wheel arches that are 4 inches high. A formula car fits perfect the wheel arches are between the wheels. but a sports racer or a production car that has 1 or 2 inches of ground clearence would need the floor raised on one end. I hauled a cooper formula jr, it fits fine but the ramps had to be blocked up 4 inches to clear the transition from the ramps to the floor and the rally car had no problems . The floor is all aluminum and a formula car has lots of room around it, so it is easy to work on a formula car in the truck if the weather is bad.
