    Senior Member gbmetcalf's Avatar
    Corning, NY
    Liked: 53
    Default I need some measurements
    Ok all I have my steel all bent and cut.
    On the front beam I need the dimention from the
    Bottom of your frame rail to the centerline of
    the bottom mounting hole on the beam.
    Thank you
    BRIAN
    Eaton, OH
    I could use this info as well. (I'm re-working the front of my FV chassis for a balljoint beam).
    Senior Member Jim Nash's Avatar
    Bloomington, MN
    Liked: 67
    This is going to vary from builder to builder but, for what it is worth...The centerline of the lower beam hole to the bottom of the frame rail on the MRC is 6.88".
    Jim Nash
    Rochester, NY
    Default Crude measurement
    This is not precise, but the same measurement on the EVO chassis standing in my garage is 6 3/4
