Ok all I have my steel all bent and cut.
On the front beam I need the dimention from the
Bottom of your frame rail to the centerline of
the bottom mounting hole on the beam.
Thank you
BRIAN
Thank you
BRIAN
I could use this info as well. (I'm re-working the front of my FV chassis for a balljoint beam).
This is going to vary from builder to builder but, for what it is worth...The centerline of the lower beam hole to the bottom of the frame rail on the MRC is 6.88".
Jim Nash
This is not precise, but the same measurement on the EVO chassis standing in my garage is 6 3/4
