- 07 complete Yamaha R1 with about 600 miles. Owner says he broke the neck on the bike
- Dry sump pump (Taggart)
- Taggart original dry sump pan
- Citation structural dry sump pan - will bolt directly to Citation and probably Swift. An adapter plate can probably be made for 98+ VD
- This engine has slipper clutch, stiffer springs included
- Wiring harness
- Re-flashed ECU to racing specs
Engine is crated and ready to go. The 07/08 is noticeably stronger than the 06, which pulled the same as an 06 GSXR in another FB.
$3000
Also have Citation steel tube structure engine cradle ($200 or best). Other engine pieces and fuel pump / regulator available too.
