How is the Borland Sabre 02 cooled?
http://www.juniorracing.com.au/press..._1005_0510.pdf
I think they run the fan shroud in Australia.
Brian,
The Australian FV rules mandate the use of a stock fan, driven by the stock belt and stock size pulley. Sort of a built in rev limiter and cooling is never an issue.
When we put the Jacer together, it was designed/constructed with a fan in mind. To keep things simple and get the car on the track, a fan was installed. We simply used a pulley small enough to run 1:1 (rather than the stock (2:1) and it worked fine until a beltless system was designed and constructed.
Bill Bonow
Bill Bonow
